My H&R drop is uneven... Lower in the rear. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2011, 01:48 AM   #1 (permalink)
View Lamski's Photo Gallery
Gen6 My H&R drop is uneven... Lower in the rear.
2011 SE I4
So after the issue I had with my speedbumps I decided to swap my Solara Teins with H&R springs to ride a bit higher. The speedbump issue is resolved however I'm having another issue with ride height.
It's been 4 days so far and they have settled a bit but not the full drop specified by H&R. My Hub to fender measurements:
Stock height hub to fender: 15.5" all around (almost exactly 15.5" on all 4 corners)
H&R height hub to fender: Front Driver=14.5", Front Passenger=14.75", Rear 14.25" on both
The H&R rear is perfect and nearly exact to the specified drop (1.3" specified, 1.25" actual). It's the fronts I'm worried about. I'm seeing only a 1" drop on the driver side and a .75" drop on the passenger side . If I could get to the 1.4" specified I think it would be perfect for me.
Can I expect the front to settle even more over time and not the rear? What are the possible issues I could have? I'm pretty sure they were installed properly as they are difficult to mess up and have the height be affected. Everything feels and sounds perfectly normal while driving. The ride quality is great.
Has the front H&R springs been known to take longer to settle then the rear? I don't really want the rear any lower. And yes, I have the H&R set for the 4cyl (54685), not the 6cyl.
Lamski is offline   Reply With Quote
Old 07-27-2011, 07:30 AM   #2 (permalink)
trdcamry1211's Avatar
View trdcamry1211's Photo Gallery
it might take a few days to settle
2007 SE V6
6 speed auto
stock remote start
jbl
6000k 55 watt ddm hid kit
trdcamry1211 is offline   Reply With Quote
Old 07-27-2011, 08:29 AM   #3 (permalink)
PatrickGSR94's Avatar
View PatrickGSR94's Photo Gallery
Springs do not settle. If they do they're low quality POS's. What usually happens is the rubber bushings in the suspension actually tear a bit as they reset themselves to the lower ride height. Whenever ride height changes you should ALWAYS loosen all bolts going through rubber bushings and torque them to spec with the car at ride height.
PatrickGSR94 is offline   Reply With Quote
The Following User Says Thank You to PatrickGSR94 For This Useful Post:
mrdeealexander (10-08-2011)
Old 07-27-2011, 08:40 AM   #4 (permalink)
I got a kangaroo as a pet
private_number's Avatar
Gameroom cash: $342822
View private_number's Photo Gallery
Keep in mind that the rear ride height will change through out the week depending on how much gas you got in your tank
2007 I4 CAMRY LE, My ride ==> CLICK
Official gen 6 camry hellaflush picture only thread ==> CLICK
private_number is online now   Reply With Quote
Old 07-27-2011, 09:32 AM   #5 (permalink)
Banned
Gameroom cash: $216100
View BlackG5's Photo Gallery
are you sure you seated the springs correctly? they could be turned a bit causing it to be higher... maybe..??
I wouldn't think H&R would be so different, but my eibachs kinda had the same problem.. the front was wayyy higher than the rear..
BlackG5 is offline   Reply With Quote
Old 07-27-2011, 11:06 AM   #6 (permalink)
270hp = Happy Foot
Gameroom cash: $395545
View aznlunatic206's Photo Gallery
eibachs are know to sag in the rear
2011 Camry SE V6 Fully Loaded w/o Navi
V-HIDS 5000k HID Kit Low Beam, 3000k Nokya Fogs
20% Aegis Tint, 50% Front Windshield
Tein Solara Springs on KYB GR2's
aznlunatic206 is offline   Reply With Quote
Old 07-27-2011, 12:21 PM   #7 (permalink)
'11 Camry SE
exclusive's Avatar
Gameroom cash: $305680
View exclusive's Photo Gallery
I believe this is an issue because it's a SE model. I had Tein Camry springs on my '11 LE I4 and the drop was even. I now have the same springs on my '11 SE I4 and the front wheel gap is a little more than the rear.
2011 Camry SE
|| Click my car below to see my thread ||
exclusive is offline   Reply With Quote
Old 07-27-2011, 01:17 PM   #8 (permalink)
Im sure they are seated correctly. I made sure the end of the coil was butt up against the stopper on the bottom mount.
I will try loostening all the nuts on the upper mounts and reset them when the car is on the ground. When I installed them I torqued it while on the jack stands. We'll see what happens. Seems pretty far off still considering according to H&R the front should be .65" lower then it sits now which is quite a bit.
Old 07-27-2011, 02:41 PM   #9 (permalink)
270hp = Happy Foot
With my 2011 camry se v6 i have solara tein springs that dropped 2in all the way around, but since i have a v6 the front is a little lower but when first looking at the car it looks the the rear is sagging, but it just looks that way because the wheel well is smaller in the rear than the front. It does take a couple weeks for it to fully settle so give it some time. Mine took a couple weeks before it was settled all the way.
Old 07-27-2011, 05:53 PM   #10 (permalink)
^__^
alexorozco92's Avatar
Gameroom cash: $266000
View alexorozco92's Photo Gallery
Yeah, just give it time to settle.
My coils still aren't settled and it's been almost a week.
Low'N Slow Crew
08 G37: Ksport Coilovers, Varrstoen ES 2.2.2 19x9.5/10.5 +12, SPC Camber Kit
08 Camry: http://www.toyotanation.com/forum/showthread.php?t=386218
alexorozco92 is offline   Reply With Quote
Old 07-27-2011, 08:53 PM   #11 (permalink)
ilikecamrys
Cking's Avatar
Gameroom cash: $532185
iTrader Score: 17 reviews
View Cking's Photo Gallery
So your saying Swift and BuddyClubRacing springs are pieces of sh1t?
My 10k swift 186mm or whatever springs settled in 4 days after driving like 200miles.
Yours should settle in a couple of days, but I had TRDs (re-labeled Eibachs) and the front was higher than the back.
2k8 V6 Camry SE\\55w6000kHID||3000kfogs||Work Emotion CR-ULTIMATES
||BuddyClub Coilovers||SPC Camber Bolts||TRD Dual Catback Exhaust
||Megan FrontTowerStrutBar||StopTech Slotted Rotors||PosiQuiet Pads
||Fujita ColdAirIntake||My thread!||TN lanyards!||
Cking is offline   Reply With Quote
Old 07-27-2011, 09:27 PM   #12 (permalink)
WWDDD?
AKM83's Avatar
Gameroom cash: $191650
View AKM83's Photo Gallery
Could be normal. I had eibachs on my old ride and the rear always looked lower. It could've been shape of the fender, but this is a common problem with lowering springs.
AKM83 is offline   Reply With Quote
Old 07-28-2011, 01:17 AM   #13 (permalink)
ilikecamrys
Cking's Avatar
Old 07-28-2011, 01:42 AM   #14 (permalink)
Just curious if my initial measurements were accurate... I have them writen down so I'm pretty sure but a second/third comfirmation never hurts. I had 15.5" on all 4 corners (measured from center of wheel hub to fender above wheel) on my 2011 SE I4 stock springs. Anyone running stock springs want to measure real quick?
Also here is a pic I took today. Kind of hard to see with the sun and shaddow but it's all I had time for... Doesn't look too bad but it definitely doesn't measure what it should. The fronts should be about .5" lower
On H&R 4 days after install..
For reference... on Solara Teins taken a couple weeks ago:
Old 07-28-2011, 07:16 AM   #15 (permalink)
Did you loosen all suspension arm bolts and re-torque at ride height to prevent bushing preload at ride height? If not then your bushings probably tore a bit on the Swift springs, which you preceived as "settling".
