Then the ext3nded warranty will cover it. Lots of things that could leak when it is hot and not cold. If you could smell coolant, the heater core would be suspect, and it doesn't have to leak much for you to smell it. I had an 85 VW Jetta whose heater core was recalled long after warranty expired. Sure enough, it was leaking, but rarely did I add coolant. You could have a leak on the pump shaft. Leak around hose connections. If they can't find a problem, I'd fill the radiator and tank when it is cold and then watch it daily or weekly. You are going to lose some coolant to summer evaporation so everyone should watch it this time of year. If you are losing excessively, then yes, it is going somewhere.
