Originally Posted by prailone
the fuse is there. I had to wire the switch which i think is the problem but i have not checked the relay since its behind the fuse panel and I don't know how to get to it.
you can wire the switch as many different ways as you want, but if the relay is not present it won't work. check that the relay is there... you will need to take the dash trim off and the metal support bar behind the dash trim off to access the back of the fuse panel.
you will have to lie on your back to really see it, unless you're really flexible. if you're a big guy like me, it's still going to be a tight fit even with the dash trim removed and the seat all the way back.
