suspension sounds from 05 Camry with Eibach springs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2011, 12:15 AM   #1 (permalink)
View racerchoi's Photo Gallery
It's been about a month since i installed the Eibach springs in my 05 Camry. Lately I've been noticing a much frequent clunking sound coming from the front every time I pull out of my driveway. Is this normal with Eibach springs?
I used the same strut mounts that I had. Also had a camber kit installed. Any suggestions as to what it could be?
racerchoi is offline   Reply With Quote
Old 08-12-2011, 03:35 PM   #2 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
is everything tight? check the sway bar links (both front and rear), make sure those are tight. they are commonly a source of clunking noises.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 08-12-2011, 03:52 PM   #3 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1078058
iTrader Score: 7 reviews
Check your mounts, could be loose or even broken. If they are broken replace them asap because you will snap your springs.
I had this happen, my mount broke and i turned the wheel and the spring snapped.
2002 Camry SE V6 "Snow White"
Old 08-13-2011, 01:27 AM   #4 (permalink)
Visually the mounts look good. How can I tell if they are broken from under side, or would that be very obvious?
If i change the mounts, will i need to remove the strut/spring?
Does any 1 know what torque the mounts should be tighten? Or should I tight it to the max?
Old 08-14-2011, 03:25 AM   #5 (permalink)
Mounts were very loose, I can't believe they were that loose. Tighten them up and drove around the block, so far no more clunking. Hopefully that was it. Still can't believe why they got that loose.
Old 08-15-2011, 02:42 AM   #6 (permalink)
View Lamski's Photo Gallery
Which part was loose? the upper nuts, the lower large nuts?
Lamski is offline   Reply With Quote
Old 08-15-2011, 10:41 AM   #7 (permalink)
all 3 upper nuts shown in pic on both sides were very loose. I saw the the guy use an impact wrench when he installed the struts and springs a few months ago, so they must have not have had enough torque applied to them.
Old 08-15-2011, 06:15 PM   #8 (permalink)
shops just don't take the time to properly torque anything anymore. this is why whenever i'm able to, i do the work myself.
2005 Camry "LE"
Old 08-18-2011, 12:49 PM   #9 (permalink)
Unfortunately the clunking sound has returned (not as much though) and I'm leaning towards the mounts being bad after all. What a bummer, i should have just done it when I did the struts a month ago. grrrrrrrr!
Any 1 know what the torque setting should be on the struts? I read 152 to 167 lbs/ft but not too sure.
Old 08-18-2011, 09:49 PM   #10 (permalink)
I assume you mean strut to knuckle torque: Front Struts - 155 ft-lbs; Rear Struts - 188 ft-lbs.
dunno why the rears are higher, but that's what it says in the repair manual.
2005 Camry "LE"
