Replacing Cabin Airfilter on 07 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2011, 02:15 PM   #1 (permalink)
2007 Titanium Camry CE
07i4's Avatar
View 07i4's Photo Gallery
Gen6 Replacing Cabin Airfilter on 07 Camry
I followed the instruction on this video. I have to say it is very misleading
The limiting stop does not need to be taken out. It snaps right off and will not get in the way.
But I am now stuck with the compartment not coming off. I push hard on the back but it does not look like it want to come off. Pushing inward from the side does not loose it up much. Any tips?
07i4 is offline   Reply With Quote
Old 08-12-2011, 03:31 PM   #2 (permalink)
Bills07CamLE's Avatar
Gameroom cash: $220300
View Bills07CamLE's Photo Gallery
Check the DIY for the glove box light change it tells you how to take the whole thing out.
Master List of LEDs Bulb Sizes & DIY/Tutorials for Interior/Exterior Lights
Bills07CamLE is offline   Reply With Quote
Old 08-12-2011, 04:57 PM   #3 (permalink)
Got Retrofit?!?!
BlackCam09's Avatar
Gameroom cash: $530410
View BlackCam09's Photo Gallery
you pull towards you from the middle part.
Pioneer 7" AVH-P4200DVD|CDT Audio 6.5" CL-62Pro Comps|Alpine SPR-69C 6x9s |09 RD Alpha 15" in 2.75ft^3 @34hz |Sundown Audio SAZ1500D|Kicker ZX250.2|UR Strut Bar|H&R Springs|EE LED Tails|18" Konig Crosshair|RX330-TSX-R Clear lens Retrofit|Megan Catback|RKS Kit|UR 19mm RSB|BC Racing Coils
BlackCam09 is offline   Reply With Quote
Old 08-12-2011, 05:19 PM   #4 (permalink)
nitronate33's Avatar
View nitronate33's Photo Gallery
if you squeeze the compartment from both sides inwards, the compartment will come out. i don't push on the back like the video, i squeeze from both sides.
2005 Toyota Solara SE 2.4L
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
nitronate33 is offline   Reply With Quote
Old 08-12-2011, 05:40 PM   #5 (permalink)
07i4's Avatar
It just say "Once all screws and bolts are removed, grab the sides, insides or anything and pull towards you. The glove box will fall. It's held in place by 3 yellow clips and 2 black ones."
I don't think any screws need to be removed. It sounded like the entire glove box assembly is being pulled out.
Old 08-12-2011, 05:55 PM   #6 (permalink)
07i4's Avatar
From your signature, I see you don't own a GEN6 Camry. Pushing back is the way to go on GEN6. Pushing inward, even if it works, is super hard. I tried again with a bigger force pushing the back and pulling the front at the same time and it came off.
But there is definitely no need to remove the limiting stop like in the video. All I need to do is snap it off side way so it is no longer attached to the glove box.
Old 08-12-2011, 06:16 PM   #7 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $477210
iTrader Score: 12 reviews
View bandit's Photo Gallery
Yes, the method that was linked to is removing the entire glove box housing. I did this to access the glove box bulb since using a mirror, light and tweezer didnt work. Upon removing the entire thing, I was able to access the cabin filter as well. So my method is an alternative for those who can't do it the normal way.
CarDomain
Old 08-12-2011, 07:52 PM   #8 (permalink)
View Robert1820's Photo Gallery
The little cylinder shaped thing is only a damper. You need only remove it from the glove box door. Then push in the sides of the glove box enough for the tabs to clear and let it open all the way. You have to push fairly hard. Then, all the crap in the glove box will fall onto the floorboard. But you were going to clean it out anyway, right?
Robert1820 is offline   Reply With Quote
