Has anyone replaced spark plugs on 2007+ V6 2GR-FE? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2011, 05:05 PM   #1 (permalink)
schott1984's Avatar
View schott1984's Photo Gallery
Gen6 Has anyone replaced spark plugs on 2007+ V6 2GR-FE?
Tried doing a search and couldn't find much, I think a lot of these cars are still under 100k or people are just letting the dealers do it.
Just got my 100k tranny and coolant flush done and they said it's nearly $300 to replace plugs.
Has anyone here actually done it on a 2007 or newer? Do you have to take the intake plenum/manifold off or can you manage with extensions/u-joint socket combinations?
I plan on doing it at 120k which will probably be spring 2012, so I'm trying to do research now.
At the dealer when I asked about it the guy said "Well the BOOK says take the intake off, which is why it's a 2hour (at $104/hr) job." This led me to believe they actually do with without removing it since he emphasized the "BOOK SAYS" part.
Also, I have the Toyota service manual in PDF.
If I end up trying it and succeeding, maybe I will post a DIY... I'm just worried that I'll start it and not be able to do all of them (like the middle firewall side)...
Thanks!
2007 Camry SE V6, JBL, Sunroof... Purchased Oct. 1, 2010 with 75k miles.
schott1984 is offline   Reply With Quote
Old 08-13-2011, 05:30 PM   #2 (permalink)
270hp = Happy Foot
Gameroom cash: $396245
View aznlunatic206's Photo Gallery
Havent had mine replaced yet since the car is only a year old but the spark plugs are expensive, i believe i was quoted ~$14 if i remember correctly for each plug, so for 6 of them its already $84 not including tax since they last up to 100k. From the looks of how the intake manifold curves over the other side of the engine it would look almost impossible to do without removing the whole intake manifold.
2011 Camry SE V6 Fully Loaded w/o Navi
V-HIDS 5000k HID Kit Low Beam, 3000k Nokya Fogs
20% Aegis Tint, 50% Front Windshield
Tein Solara Springs on KYB GR2's
aznlunatic206 is offline   Reply With Quote
Old 08-13-2011, 05:37 PM   #3 (permalink)
schott1984's Avatar
Yeah, they told me $10 something for each plug and online that's about right. Just don't like the idea of paying them $208 in labor plus the parts...
Old 08-13-2011, 06:03 PM   #4 (permalink)
2GR-FE FTW
View Cougs57's Photo Gallery
I have been looking into this job as well. I have an 07 with 44k on it. The reason I want to change them is because the car is going on 5 years old and they have the original plugs. That is similar to doing an oil change once in a year period and you only drove ~2-3k miles. I am just anal about this sort of stuff.
Cougs57 is offline   Reply With Quote
Old 08-13-2011, 06:07 PM   #5 (permalink)
schott1984's Avatar
Manual says 120k or 144 months... 12 years! So I wouldn't mess with em, dude!
Old 08-14-2011, 02:42 AM   #6 (permalink)
270hp = Happy Foot
honestly at 44k miles i wouldnt even worry about changing them. To schott1984, why not do it yourself?
Old 08-14-2011, 09:56 AM   #7 (permalink)
Rey
Pilot0617's Avatar
Gameroom cash: $148000
View Pilot0617's Photo Gallery
^ x1 and and you can do it you self, removing the intake manifold is easy only thing to look out for is the intake manifold gasket that should be replaced to prevent air leeks.
09 Camry Full Gen 6.5 conversion/4300K HID low beams/3000K HID Fogs/Borla exhaust/ 35 tint all around/Auto folding mirrors/Full led conversion/ K&N drop in filter/ Flux capacitor to make it go faster.
Pilot0617 is offline   Reply With Quote
Old 08-14-2011, 12:53 PM   #8 (permalink)
schott1984's Avatar
I posted this thread to help decide if I should do it myself. Have either of you guys actually done this?
Old 08-14-2011, 09:00 PM   #9 (permalink)
2GR-FE FTW
I would do it yourself if I was in your shoes... Hands down. I think I am going to do mine as well. Whenever I buy a vehicle I do a tune up on it instantly. That way I know it has been done and I know what I have. If you do it, please do a DIY. I want to know how difficult the manifold is to take off. It appears to be a plastic one like the 1zz-fe motors. The metal ones on the 2zz were a PITA!!!
Old 08-15-2011, 02:23 PM   #10 (permalink)
Gameroom cash: $195750
View ImJustMe55's Photo Gallery
I haven't done it on my Camry yet, but I've done some FWD V6's before and usually taking the intake manifold off isn't that hard. But like Pilot0617 said watch out for the gasket, if it's torn or in bad shape replace it, and cover the intake holes so you don'd drop something in you engine cause it can be hard to get it out sometimes.
It's good to go fast, but even better to be able to stop!!
2007 V6 Camry SE: TRD Air Filter, Power Slot Rotors, Hawk PC pads, Techna-Fit Braided Steel Brake Lines
ImJustMe55 is offline   Reply With Quote
Old 08-30-2011, 03:34 PM   #11 (permalink)
2GR-FE FTW
I have ordered all the parts for this. I went with the step below lazers for plugs and found them for around $6 a plug (parts store they are $10+). I got the complete intake manifold gasket set as well. Do I have to take the entire manifold off or just the portion covering the valve cover? I really think I will make a true DIY for this as no one has and plenty of people are anxious for instructions/direction on this project.
Old 08-30-2011, 06:06 PM   #12 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
You should replace the gasket no matter what-any gasket for that matter. Don't just replace it if it "looks bad". Last thing you want is to re-use the old gasket at 3k miles later, it blows. I've done a LOT of top-half engine work, gaskets are no joking matter.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 08-30-2011, 07:37 PM   #13 (permalink)
2GR-FE FTW
My question was as follows, "do I have to take the entire manifold off or does it come off in sections?" Whatever I have to take off I will replace the gasket there. I am just not 100%.
Old 08-30-2011, 07:56 PM   #14 (permalink)
Need For Speed
Don't worry, I was just putting it out there for everyone. I'm not positive what all will have to be taken off, my Cam has the 4 banger.
Old 08-31-2011, 07:59 PM   #15 (permalink)
MDT Toyota Tech
View BadChicken's Photo Gallery
yes you have to take the whole plenum off, remove the intake tubing from the throttle body, unbolt the throttle body (4 bolts), leave the throttle body hooked up to everything and just let it hang there. remove the 4 allen head bolts on the front of the plenum, 2 nuts on the front of the plenum as well (cant remember if these are there or not), there are 2 brackets on the back of the plenum that need to be unbolted. the one on the drivers side is very simple to get to, the one on the pass. side is a little harder (easier if you have small hands), you can either unbolt this one from the plenum or the valve cover (whichever you find easier), then just lift off the plenum. I've done plenty of these and i can have it off the car in less then 10 minutes, pretty easy once you start working on it. hope this helps a little, dont be scared to change your own plugs on this motor, its not that bad
BadChicken is offline   Reply With Quote
The Following 2 Users Say Thank You to BadChicken For This Useful Post:
Donald E. George (09-01-2011), SSBN (12-07-2011)
