2011 Camry Bad Wheel Bearing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-15-2011, 10:55 AM   #1 (permalink)
View JiminBrooklyn's Photo Gallery
Thought I would post this to help other Camry owners with a possible diagnosis for a bad front wheel bearing. About a week ago, I started to hear a low pitched hum from the front of the car, noticeable at first between 35 and 40MPH. Above 40 MPH, the sound kind of mixed with road noise, so it was difficult for me to determine if the sound got louder, etc.
This sound was reduced as the car was braking and disappeared completely when stopped at a light or parked in neutral.
I did not notice any change in the noise when turning left or right, but this observation MAY NOT have been accurate since I do not make many turns at 35-40 mph.
Took the car into the dealership and they diagnosed a bad front wheel bearing, which they had to order. Since this is a 2011 Camry with only 11,000 miles on it, it is a warranty repair.
Hope this helps someone else who may have a "noise" from the front end.
JiminBrooklyn is offline   Reply With Quote
Old 08-15-2011, 11:12 AM   #2 (permalink)
Gameroom cash: $162600
View Snomax's Photo Gallery
GREAT....something else to watch for!
I just crossed over the 9000 mile mark myself....same year you have as well. I will keep an ear out for this potential problem.
Thanks!
Snomax is online now   Reply With Quote
Old 08-15-2011, 11:19 AM   #3 (permalink)
View VTHokie's Photo Gallery
Glad yours was under Warranty, I just had to replace the front driver side bearing and it cost around $500 at the shop for my 2008 Camry with +126k on it.
I had similar symptoms, the roaring sound coming from the gerneral wheel area when above 30mph. It would die out from 50-65 mph, but then was a droning roar above 65. When i would turn (and pressure was applied to or released from the affected wheel) it almost sounded like a flat tire. The shop tried to tell me it was probably just tire noise, but changed his tune after I told him how many miles I had on the car.
VTHokie is offline   Reply With Quote
Old 08-15-2011, 03:05 PM   #4 (permalink)
View Nredo's Photo Gallery
Gen6
I just changed the rear bearings on my 07 SE with 77K miles. I thought it was the tires but when I got new tires it still roared. Cost about $450.00 parts and labor. You would think they would last longer than 77K ?
Nredo is offline   Reply With Quote
Old 08-15-2011, 05:11 PM   #5 (permalink)
NH603 The Crown
Mosh603's Avatar
View Mosh603's Photo Gallery
Ive put 15k on my 2011 and have not had this issue. Thank God
Mosh603 is offline   Reply With Quote
Old 08-18-2011, 04:19 PM   #6 (permalink)
Noise still there
Toyota replaced front wheel bearing and the noise is still there. Taking it back in tomorrow for the dreaded "ride with the technician". Anticipate that he will tell me that it is "normal", at which point I will ask to drive a 2011 demo from the dealer stock. If the sound is the same, I'll accept "normal". I don't think I will hear the noise on the demo, BTW.
It almost sounds like the car is stuck in 2nd or 3rd gear, a heavy hum/whine.
Old 08-18-2011, 07:07 PM   #7 (permalink)
My other cars a DSM!
View BiGbodyANT's Photo Gallery
you know i have a driverside hum too. I was thinking it was a bad tire. It definetly sounds like a wheel bearing. I got to get it checked too.
BiGbodyANT is offline   Reply With Quote
Old 08-19-2011, 08:53 AM   #8 (permalink)
View kobe4life323's Photo Gallery
did you have any steering wheel vibration problems when this wheel bearing was bad because im having a huge steering wheel vibration problem with my 11 SE they tried balancing and road force balancing multiple times. they changed my tires and put on brand new ones. and its still shaking but they dont want to deal with it they threw out their BS excuse saying since the vibration is from 70-75 we cant drive that fast we can only go 65. They said till that vibration comes under 65 MPH we cant do anything. I hate my dealership DARN YOU LONGO TOYOTA
Dropped The 20"s And Now Rollin On 18"s
kobe4life323 is offline   Reply With Quote
Old 08-19-2011, 10:03 AM   #9 (permalink)
MJZ
Bulletime
MJZ's Avatar
Gameroom cash: $438105
View MJZ's Photo Gallery
Steering wheel vibration? Your wheels are bent, your tires are warped or screwed up. Why are you taking your car to the dealership when you've modified your car?
MJZ is offline   Reply With Quote
Old 08-20-2011, 11:51 AM   #10 (permalink)
Well, second time was a charm. Took the 2011 Camry back in to the dealership and the original technician took the car for a drive and agreed that the noise was still there. As it turned out, another technician installed the first wheel bearing and when he test drove it after repair, he did not know what sound he was supposed to listen for, so he said it was repaired. However, the same sound was there.
So yesterday (Friday) the original technician replaced a second wheel bearing... the service advisor said there are two on each side? Anyway, the sound disappeared after the second repair, which means the first repair was unnecessary. Except for the aggravation of taking it in twice, I don't care... it's all under warranty.
To recap: the original sound was like a car straining in second gear, but the RPMs clearly indicated it was not a shifting problem, only a sound similar to that low, muted hum. The sound was most prevalent between 35-40 mph and between 65 and 70 mph. Other times, it blended in with road noise.
Hope this helps someone else with the same problem.
Old 08-20-2011, 01:05 PM   #11 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Hmmm, there are two wheel bearings, one on each side. So either the wrong side was replaced or it was poor workmanship in the first replacement. It's also possible that no work was done. It's happened often with old oil filter inserts getting left in the housing.
But it's that great the noise is gone and under warranty too.
Picture of the front wheel bearing, $38.79:
http://www.rockauto.com/catalog/moreinfo.php?pk=1835052
Old 08-20-2011, 05:48 PM   #12 (permalink)
According to the Toyota repair orders, here is what they did:
First [unsuccessful] repair: installed right side axle assembly because the technician thought the noise was originating from the carrier bearing on the right side axle assembly. This did not resolve the problem.
Second [and successful] repair: replaced right front wheel bearing.
Mission accomplished!
