LONG READ, but I hope most of it is relevant.
Greetings all, I am currently in the process of repairing my mother's 2004 Camry LE with the 2AZ-FE 2.4L 4 cylinder. A couple of months ago, she was driving home from church and the serpentine belt blew (at exactly 100,000 miles,) and it took the tensioner with it. I had them both replaced. However, when the belt blew, it took the coolant temp sender with it (gauge.) Well, she was driving a week or so later, and heard a "tick, stutter, or flutter" while at consistent highway speeds. She pulled over, killed the engine and let it sit for 20 or so minutes. She then tried to start it, with no luck. The engine turns over very freely and smooth. When I arrived (more than an hour later), there was liquid all over the engine, I'm unsure if it was oil or discolored antifreeze. The head gasket and valve cover gasket were in tact, with no leaks. At the time, I reached to take the oil cap off, and it was still scorching hot.
I had it towed to my mechanic and he said the engine is scrap. There is no compression. So I let it sit. Well, I have quite a bit of free time now so I decided I'll start a take-down on the engine.
I took the valve cover off to see if the cams + timing chain were in tact, they are. All the valves are opening and closing. The cylinders are pumping air (all of them,) but until Monday I have no way to check for accurate compression.
I have an OBD-II reader, and I pulled some codes.
0117 - Engine Coolant Temp Circuit Low
0327 - Knock Sensor 1 Circuit Low Input
0353 - Ignition Coil C Primary / Secondary circuit malfunction
0354 - Ignition Coil D Primary / Secondary circuit malfunction
I can't check for spark because the battery is drained, and I left my jumper cables at work =(
At least watch the video, as I am at a dead end. Thanks for anyone's help.
