A/C troubles - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2011, 07:12 AM   #1 (permalink)
View mecanocook's Photo Gallery
A/C troubles
Hello toyota friends,I am a mechanic who had the pleasure of repairing a Solara 2004.First of all,I love my friends vehicle,her camry kicks butt.I repaired her A/C and I want to share my experience with you all.I traced the problem of the flashing green light of death to a bad connection on the ECM,wich is located on top of interior fusebox under the dash beside the drivers door.The connections are needle thin and are subject to knocks and humidity.The wire in question is light blue with a white line and double silver dots along its length.It arrives from the diode located in the master fuse and relay box close to the battery.The circuit comes from the MG CLT relay which is to say magnetic clutch on the A/C compressor.That relay was replaced by an incompetant yahoo and sells for $120 from the dealer.Needless to say he put a wrong relay in its place.The correct relay has the number 90987-02028 stamped on it.I hope this info will save save a lot of heartaches for everyone who reads this,I will keep in touch.
mecanocook is offline   Reply With Quote
The Following User Says Thank You to mecanocook For This Useful Post:
Donald E. George (08-21-2011)
Old 08-21-2011, 09:30 AM   #2 (permalink)
Tech1984's Avatar
Gameroom cash: $254450
View Tech1984's Photo Gallery
Good job!!!!!!!! The MG CLT relay P# could go a couple different ways. The parts dept may not hand out the 028, (tsb P#) but the other one should do just fine too.
Yes, those microscopic connector pins wouldn't take much to cause open circuits.
Always remember the ECM in these dilemma's. Excellent work
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
Tech1984 is online now   Reply With Quote
Old 08-25-2011, 09:00 AM   #3 (permalink)
Thanx
Thank you for the compliment,I just received the relay from an online parts store.I ordered the clutch relay without telling them the number and they sent me the exact one(028) for $45.37 cdn including shipment,far better than $120 the dealer quoted.To let you know a bit more info,I had worked at a Kia dealer and had the same issues with the ECM terminals.The procerdure was to replace the female terminal,yeah right!The special crimping tool would ratchet as you squeezed the handle and only release when fully closed. Trouble is,it would squeeze so hard it would cut the wire.I liked Dodges approach better,they sell the terminal with a length of wire already crimped on.
Old 08-25-2011, 05:06 PM   #4 (permalink)
NH603 The Crown
Mosh603's Avatar
View Mosh603's Photo Gallery
Thanks for the info.
- K&N - Sports Shifter - Rockford Fosgate Audio -
- Michelin Primacy Tires
Mosh603 is offline   Reply With Quote
