Engine Maint. Light/ODB scanner - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-21-2011, 02:02 PM   #1 (permalink)
ScIrish 'n Proud of it!
Amadan's Avatar
View Amadan's Photo Gallery
Question Engine Maint. Light/ODB scanner
'07 Camry LE
No problems.
Engine maintenance light just came on, a day ago.
Connected my ODBII scanner;
will only scan with engine running.
Despite warning light, no codes revealed.
Checked fuses, etc.
Rescan, same results.
I'd like to see why the light is coming on, without visiting a repair shop.
Any thoughts, ideas, curses, or spells?
briogáide comhalta Gaeilge na hAlban
Amadan is offline   Reply With Quote
Old 08-21-2011, 03:06 PM   #2 (permalink)
View 1956kiteboarder's Photo Gallery
Hello, the "maintenance requried" light is not the same as the "check engine" light.
The "msaintenacne required light comes on when the miles ad up for your next oil chance, you reset it with the odomiter knob and the key.
1956kiteboarder is offline   Reply With Quote
Old 08-21-2011, 03:09 PM   #3 (permalink)
Bills07CamLE's Avatar
Gameroom cash: $220300
View Bills07CamLE's Photo Gallery
Originally Posted by Amadan View Post
'07 Camry LE
No problems.
Checked fuses, etc.
Maintenance required or check engine light? Each one is differnent. If its the maintanance required you might want to check your oil.
Bills07CamLE is offline   Reply With Quote
Old 08-21-2011, 03:10 PM   #4 (permalink)
Guess we posted at the same time!
Old 08-21-2011, 05:50 PM   #5 (permalink)
View Prynce3's Photo Gallery
Gen6
theres nothing wrong with you car at all if the Maintenance lights come on the camry, it comes on every 5000 miles for the oil change, its program into the computer systems for all 6th Gen camrys, so dont have to worry about just go online and research on how to reset it and it'll turn off.
Prynce3 is offline   Reply With Quote
Old 08-21-2011, 05:53 PM   #6 (permalink)
Amadan's Avatar
Now I feel silly...
Thanks... I must have been having a senior moment.
Old 08-22-2011, 02:37 PM   #7 (permalink)
Gameroom cash: $304355
That light on your 07 comes on when you start your car after 4500 miles since your oil change and will go off in a few minutes. At 5000 miles it comes on and stays on until it is reset, usually after your oil change. Your owner's manual will have the procedure to reset it.
Mike
Mike Gerber is online now   Reply With Quote
Old 08-22-2011, 06:32 PM   #8 (permalink)
Gameroom cash: $202900
View Donald E. George's Photo Gallery
Now I feel silly...
Don't worry about it. I have a "senior" moment at least once a day. And that is a convenient way to describe any screw up you might make. The US Midwest is so full of us old farts that that explanation is enough to get most individuals off of one's back.
Donald E. George is online now   Reply With Quote
