2006 Brake Light Switch Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2011, 09:28 AM   #1 (permalink)
View pj24's Photo Gallery
Yesterday I installed a new brake light switch because my brake lights worked intermittenly. The new switch seemed to fix the problem. The question I have is are you supposed to screw the new switch in all the way? After driving for about 15 minutes, the brakes started sticking and eventually I couldn't get the car to move when pressing on the accelerator. This morning I had to unscrew the new brake light switch a good bit and it seemed to fix the problem.
To install the new switch, all I did was detach the wiring, unscrew the old one, screw in the new one, and then reattached the wiring. I don't understand why that caused my brakes to stick. Any help would be appreciated.
pj24 is offline   Reply With Quote
Old 08-24-2011, 11:02 AM   #2 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $456050
View Luna2's Photo Gallery
I don’t know the factory specs, but try this;
Loosen the switch so nothing touches the brake pedal.
tighten the switch down to about 1/8 inch from the pedal to the threaded portion of the switch (only the moving center button should touch the brake pedal).
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is offline   Reply With Quote
Old 08-24-2011, 03:08 PM   #3 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
i am looking at the switch right now, what you would do is, screw the switch till the little button in the middle is even with the threads (brake pedal lever up against it). tighten the nut (carefully)..when you step on the brakes, the little button will "pop out", turning on the brake lights. you had screwed in the switch too far, in effect pushing the brakes ON....
Glenn8963 is offline   Reply With Quote
Old 08-25-2011, 01:34 PM   #4 (permalink)
Gameroom cash: $167160
View XXagon's Photo Gallery
Yesterday I installed a new brake light switch .
(The following is partially taken from the service manual.
Hope it helps)
Insert the stop light switch until the body hits the cushion.
NOTICE: When inserting the stop light switch assembly, support the pedal from behind so that the pedal is not pushed in.
Make a quarter turn clockwise to install the stop light switch assembly.
Connect the stop light switch connector to the stop light switch assm.
Check the protusion of the switch rod: 0.5 to 2.5mm (0.020-0.098 in.
XXagon is offline   Reply With Quote
Old 08-26-2011, 11:47 AM   #5 (permalink)
Thank you everyone for responding. That's exactly what the problem was. I had screwed in the switch too far. I have not had a problem with it since making the change.
Old 08-26-2011, 12:34 PM   #6 (permalink)
Cruisin' along
Glenn8963's Avatar
glad to hear it all worked out for you.
