6th GEN - Thumped in the rear.....help? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2011, 04:43 PM   #1 (permalink)
View Marcruger's Photo Gallery
Gen6 6th GEN - Thumped in the rear.....help?
Hi Folks, I have a new 2011 Camry with an unusual noise. It "thumps" in the rear. Here's the deal. When I start off from a stop, the rear end squats and a split second later I hear a deep muffled "thump" that sounds like it comes from inside the trunk. It sounds uncannily like a 5 pound bag of sugar sliding around in the trunk. Does anyone else have this noise? Could it be the gas sloshing to the rear of the tank?
It doesn't do it every time. It doesn't do it when I am turning and starting off at the same time.
I have checked and padded the jack with bubble wrap. The spare tire is secure. There is nothing in the spare tire well that moves. There is nothing in the storage well to the driver's side. Everything is secure in the trunk. Any ideas? If it is normal, I won't worry about it. Being new to the car, my brain is wondering if it is suspension issues.
Many thanks, Marc
Marcruger is offline   Reply With Quote
Old 08-24-2011, 04:48 PM   #2 (permalink)
Somewhat a Lurker
Gameroom cash: $311669
View Agent556's Photo Gallery
im gonna make a guess that it's the ABS test? check your owner's manual, it should describe what the ABS test sounds like
2005 Camry SE V6
http://www.toyotanation.com/forum/sh...d.php?t=343592
Agent556 is offline   Reply With Quote
Old 08-24-2011, 05:17 PM   #3 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $456050
View Luna2's Photo Gallery
Two options...
1) Sticking brake? (not likely) From a standing start, with the front wheels on pavement, rear on dirt. Accelerate, stop, Go back and look for a skid in the dirt/no treads, obvious.
2) Sloshing gas in the tank from a 3/4 or more full tank.... Very likely.... A known complaint...
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is offline   Reply With Quote
Old 08-25-2011, 04:56 PM   #4 (permalink)
NH603 The Crown
Mosh603's Avatar
View Mosh603's Photo Gallery
Brake test most likely. Happens around 7 mph or so
- K&N - Sports Shifter - Rockford Fosgate Audio -
- Michelin Primacy Tires
Mosh603 is offline   Reply With Quote
Old 08-25-2011, 05:58 PM   #5 (permalink)
Twin & (1 of 8)
Luna2's Avatar
The ABS brake test only occurs after you start the car, not after you have been driving awhile. Gas slosh most likely, check it on a full tank or a very low tank of gas.
MFG 02/25/2010
Stock, Shucks!
Old 08-25-2011, 08:00 PM   #6 (permalink)
Thank y'all for the input. It is definitely not the ABS test as it does it numerous times during a drive. It could be the gas sloshing, and that was my thought earlier. Is there any technical service bulletin on this? Any Toyota folks reading this site? Many thanks, Marc
Old 08-25-2011, 08:07 PM   #7 (permalink)
Twin & (1 of 8)
Luna2's Avatar
No TSB's issued for the Gen 6 or 6.5's.
MFG 02/25/2010
Stock, Shucks!
Old 08-28-2011, 11:46 AM   #8 (permalink)
2007 Camry SE V6
Gameroom cash: $133290
View thrawnis's Photo Gallery
More than likely it is the gas in the tank but you can try removing everything from the trunk to try and isolate the problem. Start with the trunk mats and spare tire cardboard support and jack/cardboard support, then the spare tire itself. In my case, I found that the spare tire cardboard support shifted a bit while driving causing some clunking noises so I added some high density foam along the outside edges where this piece would come in contact with the floor of the trunk.
My Update Thread: http://www.toyotanation.com/forum/sh...d.php?t=319520
2007 Camry V6 SE | Blue Ribbon Metallic | UR Strut/Sway Bar | K&N SRI | Magnaflow mufflers | H&R Springs | TSW Cadwell 19x8 Wheels | 6000k HIDs | Reus Custom Sound System | Tinted Headlights | Smoked LED Taillights | More
thrawnis is offline   Reply With Quote
Old 08-28-2011, 01:13 PM   #9 (permalink)
Rey
Pilot0617's Avatar
Gameroom cash: $148000
View Pilot0617's Photo Gallery
Originally Posted by Luna2 View Post
Two options...
Mine happens exactly at 3/4 of gas in the tank but I am used to it and its not very noticeable unless your radio is off. Solution---- keep your tank full
09 Camry Full Gen 6.5 conversion/4300K HID low beams/3000K HID Fogs/Borla exhaust/ 35 tint all around/Auto folding mirrors/Full led conversion/ K&N drop in filter/ Flux capacitor to make it go faster.
Pilot0617 is offline   Reply With Quote
