windshield washer ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-25-2011, 06:08 PM   #1 (permalink)
View petewv's Photo Gallery
windshield washer ?
the windsheld washer does not work. what could the problem be? i thought i would check the fuse . what fuse is for the washer and were ls it loc? is it under the hood ? or could it be the pump and how would i check it ?
petewv is offline   Reply With Quote
Old 08-25-2011, 06:27 PM   #2 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
What year is your Camry?
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 08-25-2011, 06:45 PM   #3 (permalink)
207 camry
Old 08-26-2011, 02:31 AM   #4 (permalink)
sxe-10's Avatar
Gameroom cash: $133154
View sxe-10's Photo Gallery
there is a fuse box inside the engine bay right next to the intake and also a second fuse box just under the steering column, to be honest i dont kno which fuse it is but it should say in the owners manual, i blew the fuse for my fog lights and i found it thru the manual
sxe-10 is offline   Reply With Quote
The Following User Says Thank You to sxe-10 For This Useful Post:
workerant (08-26-2011)
Old 08-26-2011, 07:31 AM   #5 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352660
View gdanaher's Photo Gallery
Is there water or fluid in the tank?
Can you hear the pump motor spin when you toggle the washer?
The pump motor might be locked up, or a hose might be broken. Fill the thing up, get a friend to toggle it while you put an ear down to listen for the pump, see if anything puddles up.
If it blew a fuse then there is likely a reason such as a shorted motor in which case you need to replace the pump motor.
If the tank is full, you hear the pump, nothing pools, then look at the nozzles and see if they are clogged.
gdanaher is online now   Reply With Quote
Old 08-26-2011, 08:58 AM   #6 (permalink)
thanks for the information. i looked in the owner manual could not find the fuse information. the top of the lid has the fuse information on it but i do not understand the abbreviations that toyato used.
pete
Old 08-28-2011, 09:55 AM   #7 (permalink)
Maven
gdanaher's Avatar
You can look for the right fuse all day but that is not likely the problem. Read what I said earlier, follow the directions and report back.
Old 10-10-2011, 01:14 PM   #8 (permalink)
i put in a after market pump it did not have any pressure (when will i learn not to use after market on Toyotas.)
the after market pump would only put water about 3 " up the wind sheld. order a toyota windsheld pump it works great. thanks for the help.
