4 things you need to make sure when buying new batteries.
1) CCA - make sure it is equal or higher than the one you are replacing
2) Size - not too big, not too small, height... this way it will fit in without any adjustment. Some battery compartment are tight.
3) Polarity - some battery do have these reverse, wouldn't hurt to double check it. 2 sec check wouldn't hurt as bad as if it's connect incorrectly it will........ all hell breaks loose.
4) Date - manufacture date them, and the store also mark the date when you buy. Battery have shelf life. Worse case you have to bring it back and they pro-rate your battery. So keep your receipt.
Edit: I just want to make #3 bold cause that one can really hurt you.
