2002 Camry LE Tire Recommendations? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-31-2011, 09:34 PM   #1 (permalink)
View nicshow's Photo Gallery
I'm sorry if there is already a thread that I'm not seeing but I'm needing to replace tires on this car (215/60-15). That's not the size I see listed as the original size but perhaps I'm missing something.
I'd appreciate any direction you can give me!
Thanks,
Nic
nicshow is offline   Reply With Quote
Old 08-31-2011, 09:39 PM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
The original factory installed tire size is 205/65-R15. But 215/60-R15 is acceptable as it's just a bit wider but the overall diameter of the tire is the same as the OEM.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 08-31-2011, 10:13 PM   #3 (permalink)
Is there any advantage/disadvantage to moving to that size or advantage/disadvantage to staying with original size?
Old 08-31-2011, 10:45 PM   #4 (permalink)
Yuko's Avatar
Between the size 205/65-15 and 215/60-15, the different is not very noticeable. The 215’s may give slightly better handling due to the wider thread area, but is heavier and more expensive than the OEM size in most cases.
On the other hand, the 205/65-15 size was very popular in the 90’s and into the 2000’s. This gives it a larger selection of tire brands to pick from. Generally, it is cheap than the 215's too. Best of all, since it's the OEM size, you should never have issues with tire/body clearance.
Old 08-31-2011, 10:48 PM   #5 (permalink)
Thank you! That's very helpful!
Now, in terms of recommendations in the 205/65-15 size? Are there some models that folks have had better success with?
Nic
Old 09-01-2011, 12:05 AM   #6 (permalink)
Yuko's Avatar
Like shoes, everyone will give suggest different brands they like. My recommendation is to search for any brand name tires on sale. A recognizable brand like Goodyear, Bridgestone, Falken, etc. will do fine. On many forums, Michelin seem to be the favorite. If it's a daily driver, a good all-season tire will do the job and usually provide the long tread wear. For more spirited drivers, like myself, a touring or performance tire is perfect but they do tend to have shorter tread life.
I would stay away from off-brand like BCT, Westlake, Primewell, etc. These are tires design and manufactured by off-shore companies. Yes, they do meet USDOT requirement but it’s “you get what you pay for.”
Old 09-01-2011, 08:26 AM   #7 (permalink)
Thanks, Yuko!
It looks like the highest reviewed tires in this size are the Hancook Optimo H727 or the Michelin Primacy MXV4.
If anyone has experience with either of these or with others not mentioned I would appreciate knowing!
Nic
Old 09-01-2011, 11:36 AM   #8 (permalink)
Wheel and Tire Guru
View Import's Photo Gallery
I wouldn't go with the Hankook, personally. Everyone says the mileage warranty is the best in the business, but when it comes down to it in 40k when your shoulders are showing steel, they're going to pin an alignment problem on you and void your mileage warranty. The difference between the two is that the Michelin has a larger internal nylon and steel belt package. That provides you with a more stable ride and more even wear on the tires. The Michelins will also help you get more wear and life out of the tire by reducing your rolling resistance, providing you less temperature fluxuation between hot and cold, helping increase gas mileage. Hope this information helps.
2011 Camry SE
2010 Highlander SE
2010 Tacoma Double Cab SR5
2007 4Runner Sport SR5
2005 TC
Import is offline   Reply With Quote
Old 09-01-2011, 12:40 PM   #9 (permalink)
Gameroom cash: $203000
View Donald E. George's Photo Gallery
Michelin Hydroedge or Goodyear Assurance Triple Tread would be a good choice for an all around tire. My preference is to install tires with a H speed rating. They won't go as many miles but they are built better than a P rated tire which is what probably came on your vehicle.
Donald E. George is online now   Reply With Quote
Old 09-01-2011, 10:00 PM   #10 (permalink)
Yuko's Avatar
P rated tire? The lowest speed rating allowed for passenger vehicle use is S, then T, H, V, etc. The minimum speed rating for Gen 5 Camry is "T" rated. Speed rating of P and Q is given for snow tires.
I would pick the Michelin Primacy (H rated) over the Hankook Optimo (T rated). Both are good tires and have OEM versions equipped on other factory vehicles. Don't forget that there are more tires out there than Tirerack can provide. Michelin X-Radial, for example, is a great tire only available at Costco.
