If the valves are audible on acceleration, it might be the gasoline octane you are buying is too low, or has been contaminated in some way. Consider buying gas at a different station if the fueling has been at the same location. Second, this type of noise comes when the cylinders are carboned and demand higher octane to avoid the knock. Get one bottle of RXP from the parts store, add to the gas and try it for the balance of that tank. It comes in a small bottle but helps blow carbon out to allow older cars pass emission tests. It might help here. Thirdly, if better gas and RXP don't cure the problem, the next thing to look at would be engine timing, and this is likely a chore for your mechanic. The engine should be capable of adjusting the timing to accomodate octane shifts. The knock sensor may need attention.
