Clicking sound 2009 Camry LE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2011, 11:39 PM   #1 (permalink)
View jimdundee's Photo Gallery
First time post:
Hi guys, i have a 2009 Camry LE. I got it (used with 43.000 miles in February 2011) i've noticed a clicking sound when i am turning the wheel in either direction half way or more. The clicking speeds up as the car does and slows as the car slows. It's more noticeable at low speeds. I've read about the ABS clicking when the car is started but the noise is not present unless turning.
Any ideas?
Thanks!
jimdundee is offline   Reply With Quote
Old 09-08-2011, 02:18 PM   #2 (permalink)
keep your boost up
cp44's Avatar
View cp44's Photo Gallery
It sounds like the steering wheel shaft assembly issue/TSB:
http://sumbiz03.home.comcast.net/~su...eringClunk.pdf
But its covered under the 3year/36000 mile warranty.
Check this thread out:
For anyone having steering popping and knocking syndromes...
Some people greased the shaft assembly and resolved the clicking sound temporarily.
:\Documents and Settings\aaron.wu\Desktop\LIGHTS.jpg
A wise man once said "If ignorance is bliss and patience is a virture, you'll have a good life if your dumb enough to wait"
cp44 is offline   Reply With Quote
The Following User Says Thank You to cp44 For This Useful Post:
thrawnis (10-07-2011)
Old 09-09-2011, 02:26 PM   #3 (permalink)
View standardtoaster's Photo Gallery
Sounds like a possible bad CV joint to me.
standardtoaster is offline   Reply With Quote
Old 09-10-2011, 08:36 PM   #4 (permalink)
Sean89's Avatar
View Sean89's Photo Gallery
This happened to me also. Toyota wanted me to replace the intermediate shaft and that would have cost me 700 dollars. Luckily, another dealer greased it and looks like the clicking noise/feeling has gone but who knows if it will be back. Mine is a 2009 car...
Sean89 is offline   Reply With Quote
Old 09-15-2011, 01:03 PM   #5 (permalink)
Thanks guys, i guess i'll have it greased and go from there...
Old 09-19-2011, 03:28 PM   #6 (permalink)
View Arash's Photo Gallery
I have an 2009 XLE and mine is doing the same thing, I dropped it off at the dealer this morning.. I have warranty and everything but if they make me pay anything, im just going to take it somewhere and have it greased.
Arash is offline   Reply With Quote
Old 09-19-2011, 03:31 PM   #7 (permalink)
Let me know how you get on today, I'm swamped and haven't had time to put mine in the shop
Old 09-19-2011, 03:37 PM   #8 (permalink)
Alright, so they just called and told me that the CV joint had a crack in it and it was slowly leaking oil and that it was a matter of time before the whole axle went bad, PHEW. lucky i took it in. They said that it is covered under warranty and that they will have it replaced by tomorrow morning as they had to order the parts. All I had to pay is $22 for the two day rental and put like $5 in gas in the car. WOOO
Old 09-20-2011, 10:08 AM   #9 (permalink)
What do I win???
Old 09-20-2011, 10:10 AM   #10 (permalink)
Originally Posted by standardtoaster View Post
What do I win???
a standard toaster oven?
Old 09-20-2011, 10:17 AM   #11 (permalink)
I'd prefer the deluxe model.
Old 09-20-2011, 10:19 AM   #12 (permalink)
sir i have to apologize seeing as how the funding for that is not in the budget.
Old 10-01-2011, 02:43 PM   #13 (permalink)
OK so i only just now got a free minute and jacked the car up. There is grease (small amount) coming from the outer CV joint on the passenger side
is this covered by warranty?
I should also mention that i had a blow out on that side which probably caused it, or at least Toyota will say so.
Thanks for all the help. Deluxe toaster model upgrade to the best answer
Old 10-03-2011, 09:15 PM   #14 (permalink)
Well now my steering wheel is shaking and my right axle is making a clicking noise. I am going to flip a *****. AUGH. IM GETTING TIRED.
Yes its covered by warranty. The power train warranty anyway.
