Rear View Mirroe DIY !!! with pictures - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-08-2011, 12:32 AM   #1 (permalink)
View Waldosgm's Photo Gallery
Auto-Dimming Rear View Mirror DIY !!! with pictures
ok peeps so this is my first post hopefully would help you ....
i searched couldnt find a DIY with pics ....
1. Remove battery cables
2. take your OE mirror
you'll have to unscrew your mirror (using a t20 torx)
and then pull downward with both hands n your slide it rite out.....
this is wat you'll c
3.Pull weather-stripping down past top of A-pillar
pull rite out dont be afraid you wont rip it ....
4. Remove your driver side A pillar Trim
you would see a trim retainer you can try to rotate it 90* with your finger (if you have small finger) or you can use something else...
you can kinda stick your finger between the A pillar trim and headliner
5. Remove coin tray
pull it towards you ..
6. Remove center dash panel
pull it towards you... gently because it has 10-pin a connector attach
make sure you remove the 10-pin connector
7. Now install your new Auto-Dimming mirror
just slide in where you took your old mirror off... really easy make sure you also tighten the screw
8. Route the wiring...
ok first connect your harness to the mirror and route wire between the headliner and roof, to top of the A pillar ....
(for those who dont wanna run wires on the A pillar because the air bag.. guess wat? camry already has wire on da A pillar... so no a problem at all )
also make sure you use some tie wraps.... 2 or 3 should be enough....
9. Cut about 1 inch of the plastic tubing on 10-pin connector wire bundle....
also identify your harness...
then attach a T-Tap the blue (ACC pin#8), white/black-stripped wire (GROUND pin#7)
.....make sure all wires are completely connect
Reconect your battery check if everything works and put everything back in place...
PD. you would get a "C" means calibrate once your drive around a 360deg around at 5mph or more the mirror would calibrate itselft
any questions let me know ill help ... this is a good upgrade for ppl trying to get homelink, dont be blind by ppl driving with HID, etc..
Waldosgm is offline   Reply With Quote
The Following 3 Users Say Thank You to Waldosgm For This Useful Post:
aznxenon (09-09-2011), eighty5iv (09-09-2011), unRaTeD (04-17-2012)
Old 09-08-2011, 08:42 AM   #2 (permalink)
ChrisNYC11's Avatar
View ChrisNYC11's Photo Gallery
Great DIY!!! Very detailed and looks easy to follow. Ill add this to my list of mods.
07 SUPER WHITE SE V6 I call her Four Eyes...
Check out My Update Thread!!
http://www.toyotanation.com/forum/sh...d.php?t=390290
NYC 6TH GEN CAMRY MEET FEB. 18
http://www.toyotanation.com/forum/70...n-advised.html
ChrisNYC11 is online now   Reply With Quote
Old 09-08-2011, 05:19 PM   #3 (permalink)
Toyota Freak
View gs_aristo's Photo Gallery
Nice write up you could have used the overhead wire harness as well to make things easier.
1997 Supra Turbo TT 6spd
2010 Toyota Camry SE
2011 Toyota Camry SE
gs_aristo is offline   Reply With Quote
Old 09-09-2011, 12:53 AM   #4 (permalink)
View aznxenon's Photo Gallery
Nice writeup! I plan on doing this to my gf's Camry. Which mirror did you use and how much did it cost you?
My question is however, how did you hide the wires from the back of the mirror? The stock one is a stick-on to the windshield, but the new mirror comes w/ the black cover thing?
aznxenon is offline   Reply With Quote
Old 09-09-2011, 05:22 AM   #5 (permalink)
Lol my friend told me about it and i rEad about it too ... But 2 things... 1 dont know how to take the headliner off n didnt wanna try cuz didnt wanna rip anything off ... 2 im not sure 100% wat cables did i need to hook da harness with ....
Sounds like its more simple that all i did but thats the true lol
Old 09-09-2011, 05:29 AM   #6 (permalink)
Aight sounds good ... Like a said i had hard time trying to do this to a SE cuz dealer said it aint no option for da SE (always making a drama) lol so hopefully this would help ppl up ...
Old 09-09-2011, 05:47 AM   #7 (permalink)
I used an oem camry xle i believe its a 07-12 ... Cost about $140-160
The wires from the back of the mirror r not too thick (2 wires only) so you can kinda slice it at the same time your mounting the mirror on that like thing thats holds it on da windshield ... The mirror i have came with the cover but i bought 1 from yunk yard (standard piece) the other day cuz i installed a auto dimming on a buddys car as well...
It was about $4 but imo dont look bad if u run the wires without because its not a long distance from da mirror to the headliner
Now my aunt has a prewired xle that came with auto dimming mirror but without homelink and she upgraded to the homelink one ... Ill send u a pm maybe u interesting ...
Pd. Im posting from my iphone so thats why i quote everyone ... Im not trying to quote each single reply lol .!!
Old 09-09-2011, 07:45 AM   #8 (permalink)
Toyota Parts since 1981
Gameroom cash: $148255
View DOHCammer's Photo Gallery
Very nice write-up. I would like to add that if your car is equipped with a sunroof then it is pre-wired for the auto dim mirror. Take down the sunroof switch console and the two wire harness is taped to the headliner on the drivers side. 2 scotchlocks and the install was done in less than 10 minutes. I bought the accessory mirror for a new Corolla and it fits the Camry perfectly. It's a simple auto dim with no compass or homelink.
05 Highlander V6 AWD
170K miles young
07 Camry SE V6 SOLD!!
TRD Dual Exhaust & Air Filter
DOHCammer is offline   Reply With Quote
Old 09-09-2011, 08:06 AM   #9 (permalink)
No wonder the dealer was making a big deal and said they didnt wanna do it for me cuz the car was not prewired lol ,!! Bastards .! They wanted charge me $120 for "labor" aka 10 mins. Install hummm .! Lol
Pd. Also i have 2 auto dimming with compass that can sell that would fit da camry if anyone interesting pm me ..
Old 09-09-2011, 12:15 PM   #10 (permalink)
Toyota Freak
Both my Camry's have moonroofs. But it wasn't long enough for my application since I installed a used Scion and a Maxima dimming/homelink mirror lol. I just used a test light to test the wires. Very straightforward. Most Gentex mirrors have 3 wires for the homelink ones which I wanted. Some have compass and temp which has more wires.
I also did not have the plastic wire guide that goes on the glass. Just used some small black wire loom and did the job. Best of all picked up both mirrors for about $100. My Scion mirror has the mood lights which is cool if you want a disco in your car lol
You don't take the headliner off. I used a old CD and wedged it to the front of the plastic console and it pops off the entire housing.
Nonetheless good work!
Old 09-09-2011, 01:48 PM   #11 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
Where did you purchase the mirror?
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 09-09-2011, 03:00 PM   #12 (permalink)
1blualti's Avatar
Gameroom cash: $216200
View 1blualti's Photo Gallery
^ yea man where did you get the mirror and how much? also hat color is the display? is it green or does it match interior?
1blualti is offline   Reply With Quote
Old 09-09-2011, 07:36 PM   #13 (permalink)
Unhappy
I bought from a friend that upgrade to the homelink ... For $120
Now i have two for sale pm if you interesting ..
Pd. I check a ebay store from a dealer in florida i think but they were like $250 .. Lol they r crazy
U mite wanna check from ya local dealer now .. If ur car is prewired ... It would be super easy to install ... I know that for the 07-2011 SE it aint a option thats wat i heard
Old 09-09-2011, 07:43 PM   #14 (permalink)
The compass display kinda match the interior.. A ligth blue/teal color but the green light its indicating that the auto dimming is on ...
Its a OEM toyota piece mirror but the teal color display its kinda standar on auto-dimming i guess
