Help, No Throttle Response - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2011, 11:46 AM   #1 (permalink)
View jojo52738's Photo Gallery
Today when driving my 2003 Camry(148,000miles), I lost all throttle response. Car was driving normal, I stopped at stop sign, tried to go and got NO response when applying the gas pedal. car will idle fine at about 1000 RPM's. When pushing gas pedal car does nothing.
Thanks in advance for any help...
jojo52738 is offline   Reply With Quote
Old 09-10-2011, 11:49 AM   #2 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $456050
View Luna2's Photo Gallery
Check the plate in the intake, I bet it is stuck...
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is offline   Reply With Quote
Old 09-11-2011, 10:42 AM   #3 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
the throttle bodies are known for failing in the gen 5...thats probably the root of your problem.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 09-11-2011, 12:44 PM   #4 (permalink)
I have cleaned to throttle body and replaced the pedal and pedal sensor. borrowed a code reader and it is showing P2103 Throttle Actuator control motor circuit high.
After I cleaned the throttle body, the RPM's will now go up to 2800 RPM's when in park. But, when driving there still is no throttle respond.
Old 09-22-2011, 11:49 PM   #5 (permalink)
SMR
View SMR's Photo Gallery
USA
Jojo, did you go thru a flood by any chance ? I had the same problem with my 2003 Camry where I took out the throttle body and tried to clean the throttle plate with Goop and water...bad idea.
I talked to an auto tech from Toyota and he said that moisture or water can get sucked in from the open tube that is attached to the throttle body and he said that this cannot be fixed.
I tried my own experiment after researching on the internet and I succeeded in fixing mine. I bought a can of crc electrical parts cleaner at Home Depot (I believe it is a small blue can in the home electric switches and electrical sockets section...unlike WD40 It is supposed to be safe for plastics, plus it lubricates electrical motors). Basically you squirt this stuff into the metal tube that goes into the motor gear side side and try to flush out any thing in there. DO NOT USE THROTTLE BODY CLEANER in that port. You will have to move the throttle plate by slowly opening and closing it until the throttle plate opens fully and closes smoothly. I repeated this several times. The other openings you can clean out with a throttle body cleaner. If the car still hesitates... try cleaning again. It eventually started working properly for me and I never had any problems since then.
SMR is offline   Reply With Quote
