Reverse Light not working in my camry 2004 GLI - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-13-2011, 01:03 AM   #1 (permalink)
View walsubaie's Photo Gallery
Unhappy Reverse Light not working in my camry 2004 GLI
Actulally I'd like to know how to replace button which is for reverse light .... and where I can find it ???
I have Camry 2004 GLI - Australia manufactured ...
also I'd like to get complete diagram of my car if available ...
thanks in advance for all feedbacks
Regards,
walsubaie is offline   Reply With Quote
Old 09-13-2011, 06:11 PM   #2 (permalink)
anyone can answer me ...!!??
i'm very upset
Old 09-13-2011, 06:53 PM   #3 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
button... for reverse light? unless your car was modified, reverse lights don't have buttons... they should come on automatically when in reverse...
that being said, check the easy stuff first: burnt out bulbs and burnt out fuses.
if those are not the culprits, check the wiring in the trunk. over time, the constant opening and closing of the trunk will break wires in the trunk harness.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 09-14-2011, 05:04 AM   #4 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
Regards,
i am sorry to say that particular car i am not familiar with. you also do not state whether or not it is a manual or automatic.
now, if an automatic, the reverse switch will be (in most instances) in the console, it should be a part of the "neutral safety switch",..the only way to check it, is to replace it, as there is no other repair. sometimes, do to design, the neutral safety switch, can be mounted any where's between the console and dashboard...you will have to trace the shift cable.
now, if a manual trans, it has been "known" on some vehicle makes (not just specific to any one brand)" that the reverse switch is mounted on the transmission itself. when the transmission is shifted into reverse, the switch "slides" into a slot on the shaft. you "might be able" to test that switch. but other wise, if the light bulbs are good, the wiring isn't broken, then the switch is bad. just replace it..
Glenn8963 is offline   Reply With Quote
Old 09-18-2011, 03:13 AM   #5 (permalink)
Dear All,
Thanks for all your replies .... i forget to tell you that the transmisson is automatic ...
and i hope this is the only problem which you explained to let my transmission reverse white light working again ,,,,
thanks,
