Are all your tires the same diameter and are all tires inflated to the same psig? Also,I believe there are at least two fuses and a relay for the ABS system. You might look at your owners manual to find the right fuses and inspect each. The relay can be tested with a multimeter from Harbor Freight. The dealers have a test instrument for diagnosing ABS problems. I can remember thinking to myself that NASA would have to get involved with ABS problems when I read the first reports on how that system operates. Like I said before,find an empty parking lot or street and make an emergency stop from about 30 mph. If the ABS is working, you will hear it and feel the feed back pressure from the pump pulsating the brake pedal. My 2004 only has about 50,000 miles on it, but if the ABS system failed big time, I think I would just drive the car without that feature.It is a nice feature though and saved my bacon more than once driving roads in northwest Colorado.Regards
