coolant with engine oil?!! help..tnx - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-17-2011, 12:23 AM   #1 (permalink)
sexy gen5cam of VA
02 camry LE's Avatar
Gameroom cash: $265005
iTrader Score: 8 reviews
View 02 camry LE's Photo Gallery
Gen5 coolant with engine oil?!! help..tnx
did a swaped with new radiator today cuz it has 2 cracks left and ride side (top black long piece)...
after taking off the old radiator (after the flush)o .we planed to flush the entire cycle ...Put water hose on one hose that goes to the engine....what happned...water comin out on the same hose with engine oil!! why is that?
might be a broken gasket inside?
is that why the radiator got cracked in it?
any posibility thats broken?
does it gives engine light on??
vip soon!
02 camry LE is online now   Reply With Quote
Old 09-17-2011, 05:35 AM   #2 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
well first let's look at possibilities...
ONE...the transmission cooler lines ALSO go into the radiator, so i would CHECK the fluid level of the tranny. if it is milky white, you now have a blown (or soon to be blown) tranny.
TWO...if IT IS engine oil, that too would be of a milky white color, as oil has detergents in it...now what can possibly be a problem here..??
1) blown head gasket
2) cracked cylinder head
3) cracked block
once it is determined EXACTLY what type of "oil" you have seen, you then may have to tear down the engine. even IF it is a blown head gasket...?? you STILL NEED to have the cylinder head checked by a shop for cracks, and warpage. DO NOT just put on a new head gasket..!!!
it will be (or can be) a long process of checking things, so do not rush it....
there are just too many variables that could have happened.
Glenn8963 is offline   Reply With Quote
The Following User Says Thank You to Glenn8963 For This Useful Post:
02 camry LE (09-17-2011)
Old 09-17-2011, 04:24 PM   #3 (permalink)
sexy gen5cam of VA
lots of can be and cant be rights
other variable was..
my friend who helped me with the radiator swapp
saying that i have a trans coolant? meanin cools the trans flui? kind of like dat
since u said ^^^ that trans with coolant line some kind connect?
vip soon!
Old 09-17-2011, 05:14 PM   #4 (permalink)
Cruisin' along
Glenn8963's Avatar
if your car has an automatic, the you should indeed have coolant lines from the transmission going into the radiator at the bottom of the radiator. inside the radiator tank, you will have metal lines that are in the cooler end of the radiator. those lines can rot out if the coolant isn't the correct mixture, or if it is worn out. the ending result will be the coolant will eat away (rot out) the transmission coolant lines. they are the very same metal as the rest of the radiator, which can be aluminum../???
so check the transmission fluid..as i said earlier....if it's milky white, then the transmission will be toasted as well. there "may be" a slight chance that having the transmission flushed (with a machine), "might" work......but it's no guarantee.
then the other things i had mentioned earlier...so correct diagnostics are needed here.
02 camry LE (09-18-2011)
Old 09-18-2011, 10:11 PM   #5 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
the engine in there has a known problem of head bolts failing. Which in turn blows the head gasket.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
The Following User Says Thank You to BlackCamSe For This Useful Post:
Old 09-19-2011, 08:37 AM   #6 (permalink)
Banned
Gameroom cash: $216100
View BlackG5's Photo Gallery
you might want to drain the oil and check for coolant. if you see milky oil, then its probably the head bolts/head gasket issue-- just don't drive the car until you figure it out cuz you could make it worse.. fixing the head bolts isn't that bad, there are plenty of write-ups on here..
either way, sorry to hear about the bad luck
BlackG5 is offline   Reply With Quote
