Something broken on body - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2011, 11:25 AM   #1 (permalink)
View deedoubleukay's Photo Gallery
Greetings - I have a 2007 Camry. I noticed something that appears to be broken on the body the other day. It's basically on the right rear side, in front of the rear tire (on the other side of what would be the mud guard). Any ideas on what this is? Would fixing this mean taking off a whole panel, or is this a small piece of the car that is easily swapped out? Any ideas on how much, and if its worth it to do it? Thanks in advance.
Pictures here:
http://www.flickr.com/photos/52959574@N00/
deedoubleukay is offline   Reply With Quote
Old 09-20-2011, 11:48 AM   #2 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
that is a "rocker panel"..it goes from the rear up to the front....
you can fix it, by gluing it, but it may not look good after. you can go to a junk yard and if lucky, get the same color as what you have now. so try that, go to a junk yard.
i do not know the price either from a junk yard or the dealer. you would have to crawl under there and locate mounting screws. there may be mounting screws INSIDE the rocker panel at the door sills as well.
Glenn8963 is offline   Reply With Quote
Old 09-25-2011, 07:43 AM   #3 (permalink)
View toco01's Photo Gallery
mine did the same thing,i hit a snow ball on the way home from buying it.
i took the panel off and epoxyed it,you can't tell,other wise a new panel
will cost ya about 280.00 or380.00$
i traded a 07 tacoma dbl cab trd for it because of the viberation.
this thing makes a loud ratching,and it sounds like an old pinto,it will be my last toy
toco01 is offline   Reply With Quote
Old 09-26-2011, 06:01 PM   #4 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
You can get one from a junkyard for fairly cheap, but it's not easy to find 6th gen Camrys in a junkyard.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
