48 thousand mile maintenance 2007 camry. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2011, 03:40 PM   #1 (permalink)
GO DUCKS!
View Justdiscovering's Photo Gallery
Gen6 48 thousand mile maintenance 2007 camry.
what are the maintenance checks and things they charge you for at 48k or 50k check ups?
Justdiscovering is offline   Reply With Quote
Old 09-23-2011, 07:58 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3630950
This is from Toyota's web site:
45,000 mile service guide
50,000 mile service guide
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 09-23-2011, 10:45 PM   #3 (permalink)
Gameroom cash: $182500
View Paul3637's Photo Gallery
Not much. Is yours a vv6 or I4? New or used?
Have you lost your owner's manual or did you buy it used?
All you need to do to these cars as far as recommended maintenance before 10 years/100,000 miles - whichever occurs first - is cabin filter and air filter. Coolant is 100,000 miles, transmission fluid is synthetic World Standard with no recommended change date, and Iridium plugs go 120,000 miles.
Smartest thing to do now is take it to the dealer (powertrain warranty may be nearing 5 year expiration date) and have them change your oil & filter and check the air filter and cabin filter. Either can get very dirty before the 30,000 mile recommended replacement. Oil change "specials" from most dealers include checks of all fluid levels.
If your car is a V6 - make sure the vvt-i oil line recall has been done. If not, your car is a ticking time bomb for expensive catastrophic engine failure:
https://sites.google.com/site/toyotav6oillinescandal/
If your car is an I4, have dealer inspect the water pump for leaks from the pink coolant ....... these cars are notorious for bad water pumps:
07 Camry Water Pump
As for tire rotations, by now the tires have probably been replaced and usually you get freebies from whomever you bought the tires from. However, you may be about due for brake pads so make sure you get those checked ...... can make the cost of a tire rotation worth it if it keeps you from having worn pads eat into the rotors. Rotors are very expensive to replace.
Last edited by Paul3637; 09-24-2011 at 07:01 AM. Reason: brake terminology & added links
Paul3637 is offline   Reply With Quote
Old 09-23-2011, 11:14 PM   #4 (permalink)
View ScottFern's Photo Gallery
If your car is a V6 - make sure the vvt-i oil line recall has been done. If not, your car is a ticking time bomb for expensive catastrophic engine failure. If your car is an I4, have dealer inspect the water pump for leaks from the pink coolant ....... these cars are notorious for bad water pumps.
As for tire rotations, by now the tires have probably been replaced and usually you get freebies from whomever you bought the tires from. However, you may be about due for brake linings so make sure you get those checked ...... can make the cost of a tire rotation worth it if it keeps you from having worn pads eat into the rotors. Rotors are very expensive to replace.
I can confirm the water pump issue with the I4 engines....luckily I have the extended warranty and they replaced it no issues ~62k miles.
What do you mean replace "brake linings" specifically? I am curious as I never heard about this issue.
2007 Toyota Camry LE I4
ScottFern is offline   Reply With Quote
Old 09-24-2011, 06:45 AM   #5 (permalink)
Pads, not linings, sorry.
Slip of the brain, sorry. I meant pads, NOT linings. Drum brakes in older vehicles used to require linings on all four wheels (like ages ago) .... then many had front disc brakes, rear drum because it was difficult to engineer an emergency (parking) brake that worked. The last vehilce I had with rear linings was a 92 Toyota 4WD V6 pickup.
http://brakeperformance.com/brake-sh...rake-Shoes.php
Old 09-24-2011, 09:38 AM   #6 (permalink)
Gameroom cash: $555540
View Camread's Photo Gallery
07 4cyl w/100k miles here. my maint: change oil every 5k, 2nd set of tires, new brake pads couple years ago, cabin & air filter replaced once thats it so far.
to the dark side
Camread is offline   Reply With Quote
Old 09-24-2011, 02:01 PM   #7 (permalink)
Gameroom cash: $203000
View Donald E. George's Photo Gallery
Have the brake fluid replaced. DOT3 and 4 brake fluid is hygroscopic[it absorbs moisture] and moisture in the brake fluid can corrode internal parts of the brake system. Regards
Donald E. George is online now   Reply With Quote
Old 09-24-2011, 02:44 PM   #8 (permalink)
Gameroom cash: $418500
View tengiday's Photo Gallery
My car is going to have 45K-mile service soon. How do I know that my water pump needs to be taken care of. I found no leaking under the car. What is the cost for inspecting this water pump? Is water pump issue so common that it will eventually fail for my car?
2008 Toyota Camry LE I4 - Modifications as if they come with the car.
- TRD wheels, TRD suspensions
- OEM replica navigation with iGo/Tomtom/...
- Folding LED signal side mirrors with JDM control switch
- HID retrofit headlights with S2000 projectors and Denso ballasts, fog lights
tengiday is offline   Reply With Quote
Old 09-24-2011, 07:31 PM   #9 (permalink)
GO DUCKS!
Ok. how much does this check cost approx? And how much does an alignment cost?
Old 09-24-2011, 09:48 PM   #10 (permalink)
My dealer charges about $90 for the alignment.
Old 09-24-2011, 10:59 PM   #11 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
if you see whitish/pinkish residue anywhere near the water pump or on the hood (slings from the belt) than the water pump is leaking. also if it makes a lot of noise, the bearing is going on the water pump. yes, water pump is a very common issue on the I4 for some reason...
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
The Following User Says Thank You to LE05 For This Useful Post:
tengiday (09-25-2011)
Old 09-25-2011, 06:37 AM   #12 (permalink)
Cost of services for 07 I4 Camry - Jacksonville
There are 8 Jacksonvilles in the USA. Assuming you are in Florida, like about every Toyota dealer, they have serivce specials that are typically cheaper than Jiffylube. [I notice you joined toyotanation in August so I am assuming you bought it used and don't have service records.]
Arlington Toyota (Jacksonville FL) has specials almost identical to where I take my car (Bob Tyler Toyota, Pensacola FL).
Here is your link and here is what you should make sure are checked and replaced if necessary and it should cost:
http://arlingtontoyota.calls.net/servicespecials3.htm
(plug in 30000 & 50000 miles to get all coupon prices)
Oil & Filter: $24.95 (same 29 minute in and out guarantee as my dealer)
Engine air filter if needed: $22.95 (no charge for labor, same as my dealer)
Wiper Blades: $19.90 (get this done for sure if you don't know when or if last repaced - all you need is a scratched windshield or to get caught in a downpour and unable to see the road)
Battery charge: This should be free and done automatically as part of oil change & inspection. Since your car over 4 calendar years old, remember that Florida heat is murder on batteries. New premium batteries are about $120 at deakers, $100 at Walmart ..... 5 year bargain batteries run about $70.
Cabin Filter: This is about the only classic dealer "rip." Dealer "special" price is $49.95. Double the cost of the oil change yet done in about 3 minutes. You can do it yourself in 5 minutes (maybe 10 if first time and not mechanically inclined). Instructions on how to replace it are in the owner's manual - filter is located in the glovebox. You can get them at WalMart or autozone for about $10 but the best replacement is a Fram Fresh Breeze http://www.framfreshbreeze.com/instr...7/TOYOTA/CAMRY - about $20 which catches everything - I put a new one in myself at 29k miles and when dealer checked mine at just about 40k miles ..... it was fllthy & disgusting so I went ahead and let dealer replace it at ripoff price.
Tire rotation & brake inspection: If you don't get "freebies" from wherever the last tires were purchased, dealers typically charge about $20 on top of an oil change. Their brake job coupon price of $109 per axle is pretty good in the event you need front brakes (unlikely unless car is driven hard) but does not include turning rotors if needed.
Alignment: Unless you have uneven tire wear or your car is pulling to the left or right on level highway ..... forget it. It costs as much to check as it does to do it at most dealers. Dealer specials run $80-90 usually. Don't have it done by a shop without proper equipment and ASE certified mechanic or the cure will be worse than the disease.
Bottom line: if you don't need battery or brakes, you should be able to get your car in good shape for about $100 and under 1 hour at dealer.
Old 09-25-2011, 10:28 AM   #13 (permalink)
GO DUCKS!
So I can do this for half the price myself?...
