Please help, 2007 Camry not starting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-24-2011, 07:16 PM   #1 (permalink)
View d-d1200's Photo Gallery
When I try to start my 2007 Camry and turn the key, the dashboard lights come on with the oil symbol, the battery symbol and the check engine symbol. There is no click from the engine when I turn the key over, the lights just turn on. The headlights and tail lights work, so I'm guessing the battery is OK...does anyone know what could be wrong? My car has never had a history of problems; a few weeks ago I left a light on and drained the battery, but after jumping it then it's been driving fine for a few weeks. Any help would be greatly appreciated.
d-d1200 is offline   Reply With Quote
Old 09-24-2011, 10:34 PM   #2 (permalink)
Joined the dark side. :D
Gameroom cash: $656491
View workerant's Photo Gallery
That drain might killed your battery. Have it check out, it's free.
workerant is online now   Reply With Quote
Old 09-24-2011, 11:05 PM   #3 (permalink)
View ScottFern's Photo Gallery
Almost sounds like it could be either the alternator or the battery.
2007 Toyota Camry LE I4
ScottFern is offline   Reply With Quote
Old 09-25-2011, 12:27 AM   #4 (permalink)
molson.david's Avatar
Gameroom cash: $295253
View molson.david's Photo Gallery
looks like 12V goes to ignition lock, but it doesn't go any further.
check ignition lock, maybe it's worn or some wires loose.
also check wires on starter (corrosion/oxidation)and see if there is some fuse for starter, not sure if such fuse exist but check fuse box anyway.
if lights work your battery is fine.
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
molson.david is offline   Reply With Quote
Old 09-25-2011, 12:42 AM   #5 (permalink)
View jay2kony's Photo Gallery
if anything you should try to jump start your car and have it charge your battery and go to advance auto or autozone and have them check out your battery and if its bad replace it cause thats what happened to mine so i switched to a optimum battery works like a charm
jay2kony is offline   Reply With Quote
Old 09-25-2011, 01:35 AM   #6 (permalink)
View core2kid's Photo Gallery
Check your battery. I had a similar problem in my Celica. If I turned the radio, headlights, and interior dome light, I'd see the dome light fading. Try as many electronics as you can and honk the horn. You might see one of them dim. If so then it's your battery.
core2kid is offline   Reply With Quote
Tags
2007, camry, check engine, starter
