ABS & Brake light is on, how do i diagnose & clear these lights 06 solara - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-26-2011, 08:21 AM   #1 (permalink)
View MIAKIA's Photo Gallery
Cool ABS & Brake light is on, how do i diagnose & clear these lights 06 solara
just need help diagnosing this. the mechanic is too much just to tell me the problem. also the anti-skid tire lights is on too.
MIAKIA is offline   Reply With Quote
Old 09-26-2011, 02:35 PM   #2 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
First thoughts...
1) Check your brake fluid. Is it low? Top it off-but make sure it's not leaking.
2) ABS/wheel speed sensor went out. I had that happen in my last car and it caused all the above mentioned lights to come on.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 09-26-2011, 04:34 PM   #3 (permalink)
Gameroom cash: $203000
View Donald E. George's Photo Gallery
The sensors at each axle can be tested with a multimeter from Harbor Freight. The front sensors can be unbolted and removed from each axle. The real sensors are much more difficult to remove. For the rear sensors, you have to remove the hub assembly from the suspension member and then the sensor has to be pulled out of the hub.
Donald E. George is online now   Reply With Quote
