As far as I know, the foglights are only supposed to come on with the low beams anyway (factory fogs). My 2011 SE fogs won't come on with DRL or parking lights, and neither will any other 2010-2012 Toyota with factory fogs sitting around the dealership.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
The fog relay works as an "AND" circuit. Two criteria must be met before the relay will activate to turn on the fog lights.
1) The tail lights must be on.
And
2) Only the low beam headlight must be on.
If either is missing (1) or (2), the fog lights will be off.
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010 Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
What they said. lol. I was starting to wonder. Anyone have a quick and easy DIY to fix this problem? I woudl love to be able to turn my fogs on by themselves
There are several tricks you can use to achieve the effects you want. The current 12v supply to the coil is from the tail light circuit, which only allows the fog lights to be activate with the low beam bulbs.
You could move the source 12v to the coil, to an accessory circuit that would apply the 12v to the relay coil, any time the engine is running (the light switch must still be in auto/low beam). The result should be DRL and fog during the day, normal operation after dark.
The simplest way to achieve Fogs all of the time is to go after market and connect it the way you want.
There are several in-depth threads on this topic for the gen6.... please, search.
