all tires are fine, check tire light still on... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2011, 07:07 AM   #1 (permalink)
GO DUCKS!
View Justdiscovering's Photo Gallery
Gen6 all tires are fine, check tire light still on...
07 Camry
even checked the spare... Advice?? Btw. Already searched, found questions but no answers..
Justdiscovering is offline   Reply With Quote
Old 10-06-2011, 07:34 AM   #2 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
Originally Posted by Justdiscovering View Post
07 Camry
in the owners manual, there is a way to reset that light. you'll have to try that as well. on my car (2010) the reset button in on the inside lip of the glove box, where your's would be, i do not know for sure.
if this does not shut off the light, then the receiver may be bad?? if there is a fuse for that, check it out as well.
i cannot remember who told me this, but the valve stems act as the "antenna" for the system..if that is true, do you have the factory valve stem caps on, or did you put on metal valve caps..????
if you have metal hub caps on (instead of the plastic factory), is the metal touching the valve stems..??
if none of this helps you, hopefully someone else will be here for you.
Glenn8963 is offline   Reply With Quote
Old 10-06-2011, 12:24 PM   #3 (permalink)
View John1960's Photo Gallery
You are correct, the valve stem is the antenna. I believe this is the case in all direct monitoring systems.
Occasionally, the signal can't be read and you need to have the TPMS recalibrated.
Most better tire shops have a device like this to do the job:
http://www.nitrogentiremachine.com/t...alibrating.htm
John1960 is offline   Reply With Quote
Old 10-06-2011, 12:40 PM   #4 (permalink)
GO DUCKS!
i have the factory ones on
Old 10-06-2011, 01:24 PM   #5 (permalink)
Have you verified the pressure with an accurate guage?
Have you tried the reset?
Old 10-06-2011, 01:33 PM   #6 (permalink)
GO DUCKS!
whats the Pressure supposed to be at?
Old 10-06-2011, 01:38 PM   #7 (permalink)
Check the inside of your drivers door or the owners manual. Usually, you can't go wrong with about 32psi, cold.
Old 10-06-2011, 01:38 PM   #8 (permalink)
GO DUCKS!
they are average at 28-29
Old 10-06-2011, 01:40 PM   #9 (permalink)
GO DUCKS!
30 Psi it says.
Old 10-06-2011, 02:06 PM   #10 (permalink)
Provided your gauge is accurate, I don't see a few pounds tripping the light. I would set them all to 32 any way and see what happens.
Old 10-06-2011, 02:08 PM   #11 (permalink)
GO DUCKS!
well the problem is i did that like 2 weeks ago, and the light stayed on, and it was crazy hot then, but now its in the 70s maybe the PSI dropped cause of temp change? ill reset the light to see what happens..where is the button?
Old 10-06-2011, 03:57 PM   #12 (permalink)
Taken from another post on the forum:
On the left hand side, inner wall of the glove box, behind the plastic lip of the actual glove box and the wall, near the front you will find a button. Hold it down for 10-15 seconds and the indicator light will flash. after 4-5 flashes it will go away! All reset
