3 or 5mm spacers in rear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2011, 12:44 AM   #1 (permalink)
nuchieboy's Avatar
Gameroom cash: $203799
View nuchieboy's Photo Gallery
Gen6 3 or 5mm spacers in rear
I want to push the rears out on my 09 se. i got 225/55/17's all around but the rear is just a little sucked in. What do you guys think will do the trick? i heard that 5mm is the max we can run in the rear. Is it def safe if I run 5mm on stock studs?
2009 Camry SE V6 loaded
Mods: Borla Dual Exhaust with no resonator, K&N Intake, 5k HID headlights and 5k HID foglights, LED Tail lights, Complete interior leds, Ultra Racing Front Strut Bar, Ultra Racing 19mm rear sway bar, 20% tint, Rosen navigation system, 19 inch ASA GT1 wheels
nuchieboy is offline   Reply With Quote
Old 10-09-2011, 06:50 AM   #2 (permalink)
View Twiztedxtasy's Photo Gallery
Yes you can. If you can get 4 turns on the lug nut (which you can) it's fine. And yes, anything above 5mm you'll need extended studs. So long your torque everything to proper spec nothing will go wrong
Rep CiB like a bawse.
Twiztedxtasy is offline   Reply With Quote
Old 10-09-2011, 10:25 AM   #3 (permalink)
molson.david's Avatar
Gameroom cash: $295253
View molson.david's Photo Gallery
get ET (extended tread) lug nuts.
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
molson.david is offline   Reply With Quote
Old 10-09-2011, 07:33 PM   #4 (permalink)
nuchieboy's Avatar
Gen6
nice! u suggest h&r or ichiba? and can i use the stock lugs?
Old 10-11-2011, 01:09 AM   #5 (permalink)
nuchieboy's Avatar
Gen6
anybody?
Old 10-11-2011, 06:27 PM   #6 (permalink)
Will
willt's Avatar
iTrader Score: 7 reviews
View willt's Photo Gallery
both are good brand but h&r i think is better oh if you get 5mm post pics maybe ill do it myself
L-OO-k at MEE...
willt is online now   Reply With Quote
Old 10-11-2011, 08:08 PM   #7 (permalink)
ELiTeCReW69's Avatar
View ELiTeCReW69's Photo Gallery
Yeah nuchieboy ive been thinking about throwing some spacers on my 09 se let me know how it worked out and if you do some before and after pics. that would be cool
ELiTeCReW69 is offline   Reply With Quote
Old 10-11-2011, 08:11 PM   #8 (permalink)
270hp = Happy Foot
Gameroom cash: $396245
View aznlunatic206's Photo Gallery
I tried on 10mm in the rears a while back and it looked real good, almost flush i believe.
2011 Camry SE V6 Fully Loaded w/o Navi
V-HIDS 5000k HID Kit Low Beam, 3000k Nokya Fogs
20% Aegis Tint, 50% Front Windshield
Tein Solara Springs on KYB GR2's
aznlunatic206 is offline   Reply With Quote
Old 10-11-2011, 08:24 PM   #9 (permalink)
View pr0necr0's Photo Gallery
Did you get the extended lugs with the 10mm's?
pr0necr0 is offline   Reply With Quote
Old 10-11-2011, 08:31 PM   #10 (permalink)
270hp = Happy Foot
i only tried them on to see how they would look like since they where on my cousins car. yes it was with extended studs.
Old 10-11-2011, 08:39 PM   #11 (permalink)
nuchieboy's Avatar
Gen6
well i went with the h&r 5mm cause i didnt want to play with extended studs...i will post before and after pics for you guys
Old 10-11-2011, 08:42 PM   #12 (permalink)
View eddiefromcali's Photo Gallery
im using 3mm w/o extended lugs for 4yrs now, no problem
07 Camry LE V6 - TRD drop, Fujita CAI, IS350 Wheels, SE Grille
eddiefromcali is offline   Reply With Quote
Old 10-11-2011, 08:45 PM   #13 (permalink)
270hp = Happy Foot
if you get 10mm spacers, you can get them with extended studs that come on the spacers itself. I believe when i tried on spacers with stock se wheels, 10mm for the rears and 5mm in the front worked real well. It depends on how much you really want to push them out
Old 10-12-2011, 07:57 AM   #14 (permalink)
There are slip-on spacers and adapter/bolt-on spacers. Slip on spacers will work with stock studs up to 5mm. Anything above that will require extended studs. Bolt on spacers are the kind that have studs mounted into the spacer and then you bolt the spacer to the stock studs. Problem with bolt on spacers is that anything below 25mm will require you to trim part of the stock studs that is sticking out in order for the wheel to sit flush (UNLESS your wheel has backspacing for the studs to stick out into.) I've been running 20mm bolt on spacers for almost a year or more. So long you torque everything and check them once every few months, everything should be fine.
Old 10-12-2011, 10:10 PM   #15 (permalink)
nuchieboy's Avatar
Gen6
so i got the 5mm spacers from h&r today and put them on in a matter of 10 mins...thye make the rear look better for sure...5mm was enough for me
