'07 camry flasher relay installation help please? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2011, 03:50 PM   #1 (permalink)
View northcanadian's Photo Gallery
Question '07 camry flasher relay installation help please?
Hi all:
I need to install flasher relay. Can't seem to get info yet on where it is and how to replace. I'm 21/2 hours away from dealer, and not able to drive car with no signal lights. I think it's under dash?...can't even get my big head in there.
Would be grateful for any advice offered...thank you!
northcanadian is offline   Reply With Quote
Old 10-09-2011, 07:11 PM   #2 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $456050
View Luna2's Photo Gallery
Originally Posted by northcanadian View Post
Hi all:
You will have to remove the instrument cluster to get to it. It is between there and the clock, closer to the cluster.
First, do the 4 ways still work?
Second, is it flashing too fast or not at all?
Third, Hyper-flash is a bulb burned out (fast flash).
Fourth, if dead, have you checked your fuse?
Last of all, this is a special solid state flasher and to keep all of the original functions, you need a Toyota flasher. [door lock/unlock confirm, 4 ways with the ignition switch off]
[No way all four bulbs are burned out?]
Good luck..
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is offline   Reply With Quote
Old 10-10-2011, 09:22 AM   #3 (permalink)
Gen6
Thank you!
All I have to do is figure out how to remove instrument cluster...I have the Denso flasher relay...appreciate your help!
Old 10-10-2011, 09:29 AM   #4 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Thank you!
Be SAFE.
Disconnect the negative battery terminal...
Then you have the relearning process for the idle to go through when done.
MFG 02/25/2010
Stock, Shucks!
The Following User Says Thank You to Luna2 For This Useful Post:
northcanadian (10-10-2011)
Old 10-10-2011, 06:44 PM   #5 (permalink)
Canada Woohoo!
Thanks to Luna 2 and Bandit (used his excellent DIY tut on electronic led flasher). I did change my 2007 Camry denso flasher, and signals and hazard lights now work fine. I did manage to break one retainer clip and screw on top of instrument cluster. That one just wouldn't come out! It was quite a job for this nervous old ludite, and would not have been able to do it without your help!
Thanks again!
Old 10-10-2011, 06:59 PM   #6 (permalink)
Twin & (1 of 8)
Luna2's Avatar
You are welcome, just pass on your know how when someone else needs it.
I am thrilled and happy it worked out for you.
MFG 02/25/2010
Stock, Shucks!
Old 10-13-2011, 12:09 PM   #7 (permalink)
Gameroom cash: $195750
View ImJustMe55's Photo Gallery
Did you have to do a idle relearn or did everything just work once you replaced the relay?
It's good to go fast, but even better to be able to stop!!
2007 V6 Camry SE: TRD Air Filter, Power Slot Rotors, Hawk PC pads, Techna-Fit Braided Steel Brake Lines
ImJustMe55 is offline   Reply With Quote
