Originally Posted by wolfatwp
my engine runs smooth in park or neutral. put it in gear and there is a slight vibration or the engine is running a little rough. is it the tranny trying to move the fluid? is this normal? is this a vaccuum leak? 2007 2.4 liter.
normal. when idling, the car isn't under any load. once put into gear, you are now under a load.
if the engine mounts were bad, every time you step on the gas pedal, the engine will try to jump out of the engine bay.
if it were a vacuum leak, you would get this at idle as well, you might even here the leak.
