2AZ-FE flex plate/torque converter will not separate
I am changing my engine due to warped head. I am removing it from the top, have all external items removed, and all 6 bolts out that connect the flex plate to the torque converter. I did however leave the pulleys on the front of the engine.
My problem is: I cannot separate the flex plate from the torque converter! I have used a flat bar along with three screw drivers wedged between the plate and the converter where the mount bolts go thru, a cats paw and dowels, and a combination of wedges.
I can spin the flex plate with the harmonic balancer and the torque converter does not spin with it. so I know there is nothing attaching it. I have moved the fulcrum point of the hoist from the middle to the front to the rear of the engine to get it to tilt at different degrees. What could possibly be holding the flex plate to the torque converter? When I try to move the engine the torque converter moves with it. HELP!!!!!
