need to lift rear of car..... TRD springs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-14-2011, 02:22 PM   #1 (permalink)
Gameroom cash: $246200
View fatngs's Photo Gallery
Gen5 need to lift rear of car..... TRD springs
06 SE 2azfe 82k
front struts: kyb replaced around 30k?
rear struts: original toyota
TRD lowering springs all around
as most of you know when you install TRD springs, the drop in the rear is greater; the stock look of the car the back is slightly raised simular to a pickup truck but with the new springs the car is slightly lower all around with a more level appearance; however the wheel gap in the rear is significantly smaller in the back than the front..... now this i can live with and is to be expected.... but with people in the back seat the back end of the car is way too low..... im also planning to get new wheels and tires soon that will add an inch to the overall height of the tires and i really dont need tire rub
im wondering if anyone knows any ways to add perhaps a 1/2inch to the rear end height of the springs/struts; perhaps some kind of spacer on the either strut mount? or my job sells an adjustable spacer that you install in between the coil of the spring to add the height but im wary of changing the spring geometry
P.S. i will be changing most of the suspension componets (struts, balljoints, mounts, links, bushings, tie rods) hopefully sometime next year but the new wheels/tires will be much sooner, probably this winter
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is offline   Reply With Quote
Old 10-14-2011, 02:51 PM   #2 (permalink)
Will
willt's Avatar
iTrader Score: 7 reviews
View willt's Photo Gallery
you can get a spring/ coil booster
something like this
http://compare.ebay.com/like/3702477...=sbar&_lwgsi=y
L-OO-k at MEE...
willt is online now   Reply With Quote
Old 10-14-2011, 02:58 PM   #3 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1078058
Post a pic of your car on level ground. a side shot.
I have Eibachs which is the same as TRD and my front is lower..though i have a V6 so it drops it more.
But as stated above, you can get a spring rubber that will stiffen it up and keep the height level
2002 Camry SE V6 "Snow White"
Old 10-17-2011, 08:07 AM   #4 (permalink)
took this real quik before leaving for work.... srry for the crappy quality
Old 10-17-2011, 09:23 AM   #5 (permalink)
The way it sits is normal for the I4 with TRD springs. The spring rubber/cushion will def help with evening the ride height out.
Old 10-17-2011, 12:56 PM   #6 (permalink)
how are they supposed to be installed? between the mount/frame or take the strut appart and install it between the spring/mount?
Old 10-17-2011, 01:00 PM   #7 (permalink)
some you shove between the coil of the spring, and for that you don't have to take anything apart.
Depends on what you get, and i am sure instructions are provided
Old 10-17-2011, 01:07 PM   #8 (permalink)
wow tht sounds great..... ill havta look on ebay and see what i can find.... thnxx
Old 11-04-2011, 09:13 PM   #9 (permalink)
do u guys think something like this would work?
http://www.ebay.com/itm/Mr-Gasket-12...sories&vxp=mtr
it says its supposed to be mounted above or below the spring but it looks like it should fit in the coil like Punks said.... wut do you guys think?
Old 11-05-2011, 12:05 AM   #10 (permalink)
Powered By Chicano
7SickZ0's Avatar
Gameroom cash: $224451
View 7SickZ0's Photo Gallery
http://www.ebay.com/itm/Mr-Gasket-1285-Rubber-Coil-Spring-Spacer-1-Front-/380376284231?hash=item5890317c47&item=380376284231 &pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
those are the best ones, i have them installed in my coils in my 2010 for when i got my kids in the back seat, it wont literally raise it but it help with spring compression when you have weight, i have mine installed on the top of the coil, i raise dmy car up just a tad, installled then dropped it, they moved a tad bit until they settled in place, but i had zip tied them to the top of the strut to prevent moving or falling out on the freeway when i went on uneven road
-2010 Camry - Spruce Mica i4 <-click for update thread
Defy 20x8.5 +20 | Aftermarket Spoiler | Aftermarket Fogs | Tint | Chrome Pillars
7SickZ0 is offline   Reply With Quote
The Following User Says Thank You to 7SickZ0 For This Useful Post:
fatngs (11-07-2011)
Old 11-17-2011, 03:53 PM   #11 (permalink)
thnx for your help guys.... i installed them this week with great results.... i have pix+info on another TRD spring thread
