how to seafoam 07 w/ I4 engine? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-15-2011, 03:59 PM   #1 (permalink)
View wang's Photo Gallery
Hi guys, is there any video about how to seafoam 07 camry?
I have searched quite a while but can not find any.
A picture of vacuum line will also help.
wang is offline   Reply With Quote
Old 10-19-2011, 12:39 AM   #2 (permalink)
anyone? The video link from this thread is expired. I'm so surprised that there is no video of actual seafoaming on gen 6 camry. Probably its too dub but I just don't want to do it incorrectly and result in hurting my camry.
Old 10-19-2011, 05:28 AM   #3 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
if you need a vacuum line, you can disconnect the big line at the master cylinder brake booster. just be careful, as you might be dealing with a plastic valve it attaches to.
then follow the directions on the package.
also, if you do use the brake vacuum hose, when you re-attach it, DO NOT just drive off..you may not have any brakes. pump them up, then drive....
Glenn8963 is offline   Reply With Quote
The Following User Says Thank You to Glenn8963 For This Useful Post:
wang (10-20-2011)
Old 10-19-2011, 04:55 PM   #4 (permalink)
View keith91's Photo Gallery
I am trying to determine the right vacuum line as well (I have a I4 2AZFE engine as well), but can't find any videos or pics indicating the VSV or other vac line like discussed in the V6 seafoam threads. I took this picture from my engine and highlighted a line that looks like it connects to possibly the throttle body. (attaches to the metal part behind the engine after the rubber part of the intake) Is this the right line to use to maximize effectiveness? If not, is there another vacuum line in the pic that you can point to which will help us?
Thanks
Kg
http://img32.imageshack.us/img32/651...zfevacline.jpg
keith91 is offline   Reply With Quote
Old 10-19-2011, 05:21 PM   #5 (permalink)
Will
willt's Avatar
iTrader Score: 7 reviews
View willt's Photo Gallery
a vid but v6
L-OO-k at MEE...
willt is online now   Reply With Quote
The Following User Says Thank You to willt For This Useful Post:
wang (10-20-2011)
Old 10-20-2011, 12:52 PM   #6 (permalink)
wang: I was finally able to find the answer to your and my question in a previous thread buried on page 4. Here is the link to the thread....see the 3rd post on this page 4.
I SeaFoamed my Camry today. My experience and some tips inside...
The picture I loaded with the yellow arrow is pointing to the right vac hose to remove and use.
Good luck,
Kg
The Following User Says Thank You to keith91 For This Useful Post:
wang (10-20-2011)
Old 10-20-2011, 06:36 PM   #7 (permalink)
Originally Posted by willt View Post
Thanks. Yeah, I saw this one, somehow its different than I4 engine, which I have.
Old 10-20-2011, 06:38 PM   #8 (permalink)
Good luck,
Kg
Nice find! I will try to use it to do seafoam once I have a chance
Old 10-20-2011, 06:42 PM   #9 (permalink)
good call. IIRC, I read some where its better to use actual vacuum line than the brake booster one. I guess if I have to do it with the brake hose I will your advice for sure, thanks.
Old 10-21-2011, 05:17 AM   #10 (permalink)
Cruisin' along
Glenn8963's Avatar
yes, a vacuum line past the throttle body would be better, but sometimes, due to age of the hoses, they break when you try to get them off. i would recommend using a pair of pliers to "twist" the vacuum line first, then remove by hand. problem though is when a vacuum line does break, and you have to replace it, it is nearly ALWAYS hidden someplace you cannot get at. this is why i personally have seen many use the brake vacuum hose. it ALL eventually gets into the intake manifold, in spite of what some will say.
