Aftermarket Head-Unit Installation HELP?!?! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2011, 09:51 AM   #1 (permalink)
View tonaayyy's Photo Gallery
Gen5 Aftermarket Head-Unit Installation HELP?!?!
Hey Fellas,
I own a 2002 Camry with no Navigation or JBL System. I recently purchased this Double-DIN Head-Unit for my vehicle because I planned to add a subwoofer and amplifier.
Head-Unit: http://www.crutchfield.com/p_105KWXR...FFDouble%40DIN
I also purchased this dash kit from Schoshe for the Double-DIN
Kit:
Amazon Amazon
I just wanted to know if they're are any DIYs on removing the panels and installing the HU?
Also, where can I find the wiring color codes for Toyota so that I can soder the wires for the aftermarket stereo harness?
I appreciate the help!
tonaayyy is offline   Reply With Quote
Old 10-18-2011, 01:32 PM   #2 (permalink)
View Big Wheezy's Photo Gallery
Originally Posted by tonaayyy View Post
Hey Fellas,
Head-Unit: http://www.crutchfield.com/p_105KWXR610/JVC-KW-XR610.html?tp=5684&nvpair=AG_Size|FFDouble%40DIN
Kit: http://www.amazon.com/Scosche-Ta1467B-Pocket-Double-Installation/dp/B0007KK2ME/ref=sr_1_2?ie=UTF8&qid=1318949313&sr=8-2
You should get an adapter harness, if you get an unterminated harness the wire colors of it will match (and be labeled) your aftermarket harness, or if you want it real easy they make plug and play harnesses for most popular aftermarket radios. I highly recommend against taping into factory wires directly. As for the install, the dash kit should include instructions, these from Metra look pretty good:
http://www.metraonline.com/files/pro...NST99-8203.pdf
I used the metra instructions on my Gen 6 and they were very accurate.
-Mike
2009 Camry LE - Erisin Nav, K&N drop in, SE grille, LEDs, Gentex homelink mirror, blacked out emblems, CCFL trunk lighting, HIDs, amber fogs
Big Wheezy is offline   Reply With Quote
Old 10-18-2011, 08:13 PM   #3 (permalink)
270hp = Happy Foot
Gameroom cash: $396245
View aznlunatic206's Photo Gallery
Im sure theres pictures on how to remove the factory stereo, but ill try to help you out. The HVAC controls is one unit and if you take a flat head and carefully pry up one of the sides of the unit it will pop out, and same with the other side. after you popped off the HVAC unit you can unplug it and put it somewhere, now the stereo bezel is all once piece and slowly pull the bottom of the bezel and work your way around, it should all pop off pretty easily and once you get the whole piece out, unplug the clock and then you'll have access to the bolts to the stereo. As Big Weezy said, you should look into getting a harness for your new radio, it will take the factory colored wires and turn them into aftermarket colors that match up with your aftermarket radio harness which makes installing the new radio a breeze.
2011 Camry SE V6 Fully Loaded w/o Navi
V-HIDS 5000k HID Kit Low Beam, 3000k Nokya Fogs
20% Aegis Tint, 50% Front Windshield
Tein Solara Springs on KYB GR2's
aznlunatic206 is offline   Reply With Quote
Old 10-18-2011, 11:44 PM   #4 (permalink)
Thanks a bunch guys, i got everything off and looks good to go. I'll keep you updated with pictures of my progress!
I looked at that PDF from Metra, and so the EIA is the wiring colors for the Toyota and the other side is the wiring colors from the harness they provided, am I right?
WHERE CAN I FIND A HARNESS?! It would be great not to splice into the original wires!
Old 10-19-2011, 06:17 AM   #5 (permalink)
I'd imagine the colors are if you're using a Metra harness, those color codes are the standard colors for aftermarket harnesses, but it's rare to see OEM harnesses use the same color, but I don't have a Gen 5 to know for sure. You'd want this harness according to crutchfield:
http://www.crutchfield.com/p_1207017...ss.html?tp=736
Toyotas of that era used pretty standard harnesses, if you're in a hurry best buy, hh gregg or a local stereo shop should have a harness in stock from metra or scosche or similar
-Mike
Old 10-19-2011, 10:48 PM   #6 (permalink)
Installed successfully! Thanks for the help, i'll post pictures tomorrow!
