Originally Posted by knightnyc
Hi I am installing a multi-amp audio system in my 07 Camry LE. I am hearing some slight hissing sounds from my speakers at low/moderate levels and I suspect poor ground point is the cause. Currently the grounding wires from my 4 amplifiers are hooked up to a single distribution block w/ 8 gauge cables, which is grounded to one of the bolts for the backseats w/ a 0/2 gauge cable. I lifted the trunk lining but could not find any bolts except for the jacks storage area. The total system is about 1200 watts RMS.
A little more info:
I replaced my old OEM battery w/ an Exide AGM battery and hooked it up to the alternator w/ a 0/2 gauge cable. I ran out of cables to do the other two parts of my "big three": chassis to engine block and battery neg to chassis. They will go in the car soon.
Thanks for your input.
You could try a "mute" plug (RCA jack with the tip connected directly to the shield) to isolate if the noise is actually being induced in the amp or in the RCA/head unit, unplugging the cables may also work, but it's not always as definitive. In my experience most noise gets introduced in the RCA wiring or just as a function of the differential in the ground from the amps to the front of the car. Doing the negative terminal to chassis portion of the big 3 would be more likely to fix this than changing your trunk ground I suspect, seat bolts are usually a pretty solid grounding point.
-Mike
2009 Camry LE - Erisin Nav, K&N drop in, SE grille, LEDs, Gentex homelink mirror, blacked out emblems, CCFL trunk lighting, HIDs, amber fogs
