Faint Steering Clunk - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2011, 02:13 PM   #1 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352660
View gdanaher's Photo Gallery
I've noticed lately that I have a slight clunk that I can feel through the steering wheel, normally at very low speeds as when first moving. I can sometimes feel it at higher speeds but it tends to fade into the road noise and vibration. Acts as if it is not brakes but either a u-joint in the steering column itself or ball joint or tie rod end. Car is an 07 V6 with roughly 43k miles. Haven't had time to look at it nor take to dealer for their professional opinion, and don't recall seeing this issue previously noted on the group. Anyone else experience this, and what did you discover?
gdanaher is online now   Reply With Quote
Old 10-24-2011, 02:24 PM   #2 (permalink)
^__^
alexorozco92's Avatar
Gameroom cash: $266000
View alexorozco92's Photo Gallery
Cv boot, us guys with coils noticed it as well.
we discussed this on the hellaflush fitment thread.
Low'N Slow Crew
08 G37: Ksport Coilovers, Varrstoen ES 2.2.2 19x9.5/10.5 +12, SPC Camber Kit
08 Camry: http://www.toyotanation.com/forum/showthread.php?t=386218
alexorozco92 is offline   Reply With Quote
Old 10-24-2011, 02:34 PM   #3 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
i personally had an inner tie rod end do this. best way to diagnose is to remove the nuts holding the outer tie rods to the spindles. then when disconnected, try and lift the tie rods up the push down in a straight up/down motion. any stiffness is a bad inner tie rod...
at first, i thought bushings, and a mechanic thought that since it was coming from the steering column, it must have been the column that was binding, or the steering u-joint.
when the outer tie rod ends were disconnected like i said above, this is when it was confirmed to be the inner tie rod.
Glenn8963 is offline   Reply With Quote
Old 10-24-2011, 04:15 PM   #4 (permalink)
View qng001's Photo Gallery
I had a slight knock that you can feel in the steering and brakes last week. I sprayed some lubricate in the spline of the intermediate steering shaft. Knock went away. The car smelled of fumes for a day or two, but no more knocks.
You can find the discussion here...
Intermediate Steering Shaft - Greasing DIY
I had a clunky noise in my steering on my old Altima once, I had to replace a CV joint.
Clunk or knocks can be annoying and hard to find.
qng001 is offline   Reply With Quote
