hmm you should have taken a far side shot of the car, and anything in the trunk? Were the springs used? I have H&R springs that I bought used on my car and it sits a little bit lower in the back because of my 15" sub and big sub box, but it doesn't look like yours. You can buy spacers to put in between the springs to raise the back a little bit. Maybe you should have gotten H&R springs instead? Plus the TRD springs are known for the uneven drops.
Looks more noticeable with those fat tires...why did you go with a 225/50/18?
Yeah...I cheaped out because my friend at Discount Tire hooked me up for $525 and 45's were over $200 more because he had a special discount available on the 50's
Camrybeliever
Black 2009 V6 XLE | JBL audio | TRD springs | TRD 10 spoke 18" | 25% side & 5% rear tints | SE grille | shaved w/blacked out emblems | back up sensors
AND, if you actually look at it, it's a fairly even drop. Many other drops are actually UNEVEN, because if you drop the wheel wells the same amount (if that's what you wanted), that actually makes your car look raked. (Your underbody would no longer be parallel to the ground).
When I installed my expensive coilovers, I made sure the rear sat lower than the front and the actual heights front to back were the same.
Wow, I was thinking about putting the TRD spring set on my car but that looks way too low/aggressive for me. I wanted a very mild drop just to eliminate some of the wheel gap
