TPMS replace with new tires? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2011, 08:42 PM   #1 (permalink)
View Nakattk's Photo Gallery
Exclamation TPMS replace with new tires?
I am going to get my tires changed at Sams Club tommorrow, but I am concerned about the TPMS. I am going to Sams Club for price and location. I have never had a car with a TPMS so I do not know what req. it has for tire replacement. I told the guy at Sams Club that it has a TPMS and he said it would be ok. I have read that when the tire is replaced parts of the TPMS have to be replaced too. I dont think they are going to replace anything on the TPMS at Sams Club. Anyone have experince with Sams Club tire center? Sould I be worried about the TPMS? Or should I go to a place that only deals with tires?
Nakattk is offline   Reply With Quote
Old 10-28-2011, 09:43 PM   #2 (permalink)
Billiam's Avatar
Gameroom cash: $204725
View Billiam's Photo Gallery
Although rebuild kits sometimes include new barrel-nuts, schrader valves and seals...it's really only the seals that need to be replaced...and that's only if they remove the sensors. If you are just having your tires replaced you've nothing to worry about. No reason to remove the sensors. Any competent tire tech should know if the vehicle has TPMS, but it wouldn't be a bad idea to remind them. The sensors can be damaged by negligence.
If you want to enjoy your car....stay off the internet.
Billiam is offline   Reply With Quote
Old 10-28-2011, 10:50 PM   #3 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $477210
iTrader Score: 12 reviews
View bandit's Photo Gallery
Had my tires replaced on my SE and the TPMS did not have to get parts replaced or anything. So you're fine.
CarDomain
Old 10-28-2011, 11:00 PM   #4 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $612031
View Zembonez's Photo Gallery
Aren't the sensors supposed to have a battery life of 7 years?
Zembonez is offline   Reply With Quote
Old 10-28-2011, 11:05 PM   #5 (permalink)
The darker the better
TJHammer's Avatar
View TJHammer's Photo Gallery
TPMS swap from tire to tire pretty simple, make sure they don't scratch up nice wheels, I was in a rush last swap...went to different place and ended up with 2 ugly scratches on my aftermarkets
My Black Manta Baby (Pic spread com'n soon!)
TJHammer is offline   Reply With Quote
Old 10-29-2011, 09:13 AM   #6 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
I used to work at a Walmart TLE, which is obviously similar to Sam's Club. You won't need to take the sensors off at all, there's no need. You just have to make sure you take off and put back on the tires correctly or you could damage/break the sensors.....but you have to be really incompetent to do that.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 10-29-2011, 01:11 PM   #7 (permalink)
molson.david's Avatar
Gameroom cash: $295253
View molson.david's Photo Gallery
I've read batteries are motion charged and might last forever. almost...
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
molson.david is offline   Reply With Quote
Old 10-29-2011, 03:27 PM   #8 (permalink)
View italy7's Photo Gallery
so if i want to change tpms from stock wheels to a new set of wheels/tires it would be best to buy a rebuild kit? 100% necessary?? TIA
italy7 is offline   Reply With Quote
Old 10-29-2011, 05:25 PM   #9 (permalink)
Gameroom cash: $110300
View fj62's Photo Gallery
10 year battery life on tpms, then sensors need replaced. The batteries cannot be replaced
Dennis
2009 Highlander Hybrid, 2007 Camry, 1995 Corolla
Previous owned
1985 Camry, 1989 Land Cruiser, 1989 Corolla All-Trac wagon
fj62 is offline   Reply With Quote
Old 10-29-2011, 06:20 PM   #10 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
That would be a best case scenario.
Manufacturers of the batteries give a 5 to 10 year life span expectancy. There are many variables, such as driving style, frequency of short trips, and other factors that determine battery use.
Old 10-29-2011, 06:20 PM   #11 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
TPMS manufacturers estimate a car is driven 10% of the time, so the lithium battery should last 10 years. If the car is not moving, the sensor goes into hibernation mode. A new sensor is brought out of hibernation by pressurizing to >25 psi, sending an electronic signal or other manufacturer specific methods. Dunno about some charging batteries.
At least at Costco they cost about $10-20 each (can't remember) depending on the model. If the light is on, just bring it in. Get free lifetime rotation and balance as well. I'm sure Sam's similar. So I wouldn't worry about if it's working fine now.
Old 10-30-2011, 08:22 AM   #12 (permalink)
Billiam's Avatar
Anytime the sensors are removed the seals should be replaced. You risk an air leak if not...as the seals tend to get deformed when reused.
The Following User Says Thank You to Billiam For This Useful Post:
italy7 (10-30-2011)
Old 10-30-2011, 09:59 AM   #13 (permalink)
I totally agree with you. redo seals is a must. My daughter-in-laws 07 Rav 4 had 3 leaking tpms seals on her original rims. My son and I succeeded in breaking all 3 attempting to replace the seals. Winter Road salt caused this problem IMHO. Be careful when replacing seals. The torque on the tpms nut is very low and they should remove easily
Dennis
Previous owned
Old 10-30-2011, 11:04 AM   #14 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Very good point. Rebuild kits are available for all major brands. Even if you are reusing them on the OEM wheels, it's a good idea after 4 or 5 years.
Old 10-30-2011, 11:19 AM   #15 (permalink)
Update: Got the new tires at Sams yesterday morning and everything seems fine so far. Had to take it to another place to have Nitrogen put in b/c Sams does not have it in my area. The TPMS has not come on, so I assume everything is fine. Thanks for all the replies. Hopefully this will be around to help anyone else that is wondering the same thing.
