Replacing aux input jack on 2007? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2011, 01:30 PM   #1 (permalink)
View norbert's Photo Gallery
My aux input jack needs replacing. As best as I can see one of the prongs has broken off inside the jack. I have Googled but I can't find any information on buying the part or on how to replace it if I get the part.
Can anyone help me out?
norbert is offline   Reply With Quote
Old 10-29-2011, 11:36 PM   #2 (permalink)
Sean89's Avatar
View Sean89's Photo Gallery
Its an expensive part to replace. Runs about 100 bucks. 86190-48010 should be the part number (assuming you have the one WITHOUT the usb port).
Sean89 is offline   Reply With Quote
Old 10-30-2011, 08:28 PM   #3 (permalink)
View jay2kony's Photo Gallery
i had the same problem but heres a site where i bought my aux output for 15 bucks if you know how to replace yourself.
http://www.toyotapartscheap.com/
Search for aux
hope it helps cause ive replaced mine with this and it works great
jay2kony is offline   Reply With Quote
Old 10-31-2011, 07:05 PM   #4 (permalink)
jay2kony, thanks for the tip. The dealer said there are three choices depending on the VIN. The price was $30.
How much trouble was it to change it? Any tips would be appreciated.
Old 10-31-2011, 11:39 PM   #5 (permalink)
it was really easy like if u take out the 2 screws by the plastic pillars . and pull out the bottom of the stereo head unit where the aux outlet plug is you unplug the old AUX and unclip it out and install new one in and plug in the wiring. and redo everything you took out and it should work like a charm like mine instead of taking it to toyota where they effing charge you 110 bucks for dynastogic which is a rip .
Old 11-01-2011, 06:55 PM   #6 (permalink)
The screws I can find are hex screws. If you open the door to the area where the aux jack and power adapter is, you can see the screws I'm talking about between the open door and the bottom of the lower stereo head unit. Is that the screws you're talking about? If so, did you take the door off and how did you get it off?
Old 11-01-2011, 07:45 PM   #7 (permalink)
View Big Wheezy's Photo Gallery
http://www.google.com/url?sa=t&rct=j...qCON9g&cad=rja
You have to pull the two trim pieces off on either side and remove the screws. I think you might be able to get it off without removing the shifter plate, but if you can't you just unscrew the knob and pull up on the shift "pattern" plate first, then the outer plate with the cup holders etc.
-Mike
2009 Camry LE - Erisin Nav, K&N drop in, SE grille, LEDs, Gentex homelink mirror, blacked out emblems, CCFL trunk lighting, HIDs, amber fogs
Big Wheezy is offline   Reply With Quote
Old 11-01-2011, 09:05 PM   #8 (permalink)
thank you for explaining lol i suck at explaining things
Old 11-03-2011, 08:59 PM   #9 (permalink)
I never would have figured this out without your help. I followed your instructions and replaced the aux input yesterday. I didn't even break anything. Thanks for your help.
Old 04-07-2012, 08:17 PM   #10 (permalink)
View werdnash2002's Photo Gallery
where are you guys finding the part for $30? I looked on that website and it was close to $80 shipped. My part number for my 07 is 86190-53010
werdnash2002 is offline   Reply With Quote
Old 04-08-2012, 11:28 PM   #11 (permalink)
you go this site http://www.toyotapartscheap.com/
and you type in Aux and itll show up diagram 4 for the part......
Old 04-09-2012, 01:08 PM   #12 (permalink)
well obviously ur gonna have to put what year and what model you have for your car.. then when u put what year and model it'll show up parts/# and then u type in aux... cause if i can find it . its not that hard, unless u critically computer handicapped.
