2003 LE I suspect heavy drifting history - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2011, 10:57 PM   #1 (permalink)
View Elefant's Photo Gallery
Gen5 2003 LE I suspect heavy drifting history
I am the third owner of a 2003 Camry LE. It was a Hurst rental and I bought it from an individual. It had 100 K at purchase but I was not concerned so much about this with a Toyota. I did a brake job at 130 K and found the emergency brake pads were gone so I suspect some heavy drifting in it's history. If so, it has been pretty well absed. It has 180 K on it now and has recently developed a pretty substantial top end rattle. I am checking all my options and am considering a new crate motor. It has the 2.4 L. I'm wondering what other engines will bolt up, if any.
Elefant is offline   Reply With Quote
Old 10-30-2011, 02:25 PM   #2 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1078058
iTrader Score: 7 reviews
Does the LE have a hand e-brake or foot?
I highly doubt it has to do with drifting. They e-brake pads wear out over time.. and being a rental car and 3rd owner they have probably never been changed before.
It is hard to drift a FWD car to begin with. More so if it is a foot e-brake, which i believe the LE's came with.
2002 Camry SE V6 "Snow White"
The Following User Says Thank You to Punks_Not_Dead5 For This Useful Post:
Elefant (10-31-2011)
Old 10-30-2011, 02:35 PM   #3 (permalink)
View lemur's Photo Gallery
could have been someone forgot it was on and didnt take it off for a while of a drive. i have seen people (my mother) do this with a foot parking brake.
lemur is offline   Reply With Quote
The Following User Says Thank You to lemur For This Useful Post:
Old 10-30-2011, 08:02 PM   #4 (permalink)
Gen5 Hand brake
I have never tried drifting before so I can't talk from experience. I guess it could just as easily have been left on. The idiot light is pretty obvious though. irregardless, I am getting a really loud tapping at all rpms. it sounds like top end. Like stuck lifters or injectors. No smoke and it runs smooth. Ran a couple cans of BG through the fuel to clean it up. No change. I guess I will take it to a mechanic for diagnosis. 170 K seems too early for this kind of problem from a Toyota. My original question was, does anyone know if another year or size of Toyota engine will bolt up to this car?
Old 10-30-2011, 08:21 PM   #5 (permalink)
More Screens !
Gameroom cash: $209700
View kingnba6's Photo Gallery
i wouldnt even try to drift with a foot ebrake. thats not going to work out. people like my dad like to make sure the ebrake works so when he is coming to a redlight at low speeds he pulls the ebrake on his car. he does it like maybe once every 2 months or something. but i know one time i was in a rush and left the ebrake on for like half a block
2004 Rav4 I4 FWD
Mileage-21004 as of 8/23/11
2009 Highlander V6 AWD
Milage-15xx as of 7/9/11
kingnba6 is online now   Reply With Quote
Old 10-30-2011, 08:42 PM   #6 (permalink)
It has nothing to do with drifting lol.... It is just worn out...
As for the lifters tapping, that is due to lack of oil changes on a regular basis, or it ran low on oil a few times. The 2az engine has had issues with head gasket leaks, i would have that checked.
170k is average, but as you said it was a rental car, so it probably had the hell run out of it.
Old 10-30-2011, 11:25 PM   #7 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
+1
If that is the worst that is happening now, then it's not too bad. Most cars I come across with high mileage (including mine over time) don't have a working emergency brake. They all wear out eventually, just like every other car part will.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
The Following User Says Thank You to arabianobsession For This Useful Post:
Old 10-31-2011, 06:24 AM   #8 (permalink)
Cruisin' along
Glenn8963's Avatar
Gameroom cash: $153801
View Glenn8963's Photo Gallery
Originally Posted by arabianobsession View Post
+1
the best way (i think) to keep an e-brake working for years and years, is to use it every time we park. automatics, manuals, just use it. constant use will keep rust from building up on the cable. once rust builds on the cable, it will get stuck in its casing when you finally do want to use it.
i think the e-brake (for those of us that have automatics) becomes something we do not need. where the people with manuals use it all the time.
it's always going to be a matter of choice for some, a needed choice for others.
but as said, being a 2003 car, and now the 3rd owner, i too am sure someone forgot it was "on" and drove a bit...i know mine has a bell of some sort, when i drive with it on, and yeah..i have done that, so it does happen.
just get it fixed, so at least you have an "additional" braking component, should you ever need it...i think you'd hate to have a crash, and the lawyers ask you, "why didn't you use your e-brake"...
as for the top end rattling....that really can be just about anything. a set of testing should be done, maybe even a teardown. but if a crate motor is in your sights, then i'd go original engine size, as you may not wish to get involved with added parts like a bigger radiator and such to handle a bigger engine. maybe a bigger engine will bolt up to the tranny....but i'd rather personally not get too involved with the potential of a whole lotta headaches.
simple out, simple in..done deal.....
good luck, keep us posted.
Glenn8963 is offline   Reply With Quote
The Following User Says Thank You to Glenn8963 For This Useful Post:
Old 10-31-2011, 08:17 AM   #9 (permalink)
Thanks Guys
This is good advice guys. Any suggestions for a reliable crate engine builder? I think it's time for struts too. I put wheel bearings front rotors and pads on it at 100 K but didn't replace the e brake shoes at that time. Automatic in Kansas, I took the chance that I would never need it. I haven't yet
Last edited by Elefant; 10-31-2011 at 08:35 AM. Reason: additional Information to add
Old 10-31-2011, 08:28 AM   #10 (permalink)
View Twiztedxtasy's Photo Gallery
LS1! They're pretty cheap nowadays ;D
Jk....kinda....
But the v6 of that gen should be able to fit right in
Rep CiB like a bawse.
Twiztedxtasy is offline   Reply With Quote
Old 10-31-2011, 09:15 AM   #11 (permalink)
Need For Speed
This sounds a bit stupid but it works....the emergency brake on my Mustang doesn't work, it hasn't for years, because someone left it on when they parked it and didn't release it for well over a year. Anyway, according to the book it's a 5-6 hour job to replace it, so I just put bigger brakes on It will get fixed eventually, but for now I'm not worried (especially with the engine out of her now).
Old 10-31-2011, 09:35 AM   #12 (permalink)
I use the e-brake all the time (unless i am parked in the garage, don't want it to seize up). I was taught from day one.
With all those problems and the money it looks like you will be spending, i'd trade it in on a new(er) car.
Old 10-31-2011, 10:21 AM   #13 (permalink)
2012 Camry SE Mag Grey
SilverBullet's Avatar
Gameroom cash: $109600
View SilverBullet's Photo Gallery
Gen5
^+1,000,000.
I didn't see it mentioned but our cars (2003 LE 2AZ) have a hand emergency brake.
Lunar Mist 2003 Camry LE 2AZ-FE; 65,400 miles
OEM Spoiler | painted engine cover | plasti-dipped emblems | painted fuse box cover | carbon HVAC controls | blacked out chrome accents | window tint 35% front 20% rear | TRD performance air filter | gen 5.5 SE grille
SilverBullet is offline   Reply With Quote
Old 11-01-2011, 11:39 AM   #14 (permalink)
Banned
Gameroom cash: $216100
View BlackG5's Photo Gallery
^this. every single rental car I've ever touched has lost YEARS off its life in just a few days
but then again, it coulda been drifted, lol...
yep! Mine hardly works anymore, and the dealer actually had the guts to fail my inspection because of it :weak:
it still worked last winter tho when I cruised down almost every road completely sideways
BlackG5 is offline   Reply With Quote
