starting problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2011, 04:01 PM   #1 (permalink)
View onavi's Photo Gallery
Gen5 starting problem
Sometimes when I go to start the car, I have to turn the ignition anywhere from 1 to 6 times to get the car to start. It doesn't matter if the engine is cold or hot. I hear the engine trying to start, after like 5 sec, I stop so I don't burn the starter up. The battery is fine, there are no fault codes. Recently it seems like its taking more times turning the ignition to get the car started. Sometimes, its the first time, other time its not.
Its an 2003, I4 with 76k on it.
Any ideas?
onavi is offline   Reply With Quote
Old 11-03-2011, 12:47 AM   #2 (permalink)
View william m dowd's Photo Gallery
Try cleaning you MAS sensor and did you put in a new air filter, don't stomp on the gas pedal while starting leave it alone I don't know if any of this will help. I have 57,000 and recently had to clean out my throttle body and MAS sensor and it starts faster.
william m dowd is offline   Reply With Quote
Old 11-03-2011, 06:09 AM   #3 (permalink)
I'll have to give that a try.
Old 11-03-2011, 08:15 AM   #4 (permalink)
View Big Wheezy's Photo Gallery
Next couple of times you go to start it, turn the key to the "RUN" position (without actually trying to start the car) 4-5 times and wait 2-3 seconds each time, then try and start the car. If the check valve in the fuel line goes bad the car will lose fuel pressure while its sitting and clicking to start several times builds the pressure back up with the fuel pump, if the car starts after being switched to RUN from OFF several times it could indicate that is the problem. In an ideal world you'd use a diagnostic scanner to check for fuel pressure and ignition, but the key cycling will give you a starting point to eliminate or further research the fuel system.
-Mike
2009 Camry LE - Erisin Nav, K&N drop in, SE grille, LEDs, Gentex homelink mirror, blacked out emblems, CCFL trunk lighting, HIDs, amber fogs
Big Wheezy is offline   Reply With Quote
Old 11-03-2011, 11:07 AM   #5 (permalink)
Gameroom cash: $168100
View sam333's Photo Gallery
To add to what Big said, if that does not work then try... Does it chug and run a little rough after it starts ? If it does, try opening the throttle all the way and cranking. Sometimes a leaky injector will cause a cylinder to be flooded with fuel even before you try to start the car. Opening the throttle all the way will help clear the flooded cylinder. You can find the leaky injector by pulling the plugs and smelling for raw fuel( before you try to start it).
sam333 is offline   Reply With Quote
Old 11-04-2011, 04:43 AM   #6 (permalink)
Today, the car started on the first try every time. Today, it was a bit cooler outside than it has been recently, wonder if that has anything to do with it. This weekend, I'll clean the throttle body, MAF, and pull the plugs and check them out. Just need the car last till the spring when I'll trade it in, cause I know it needs new CV/axles, and the rack and pinion needs to be replaced as well. Can't see spending that much on a 9 year car.
Thanks all!
