2004 Toyota Camry oxygen sensor Bank 1 Sensor 1 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2011, 05:28 PM   #1 (permalink)
View kidlost2000's Photo Gallery
Need a litte help locating the oxygen sensor (Bank 1 Sensor 1) for my 2004 Carmy. It has 67K miles and decided to go out on me already.
Thanks for the help
kidlost2000 is offline   Reply With Quote
Old 11-02-2011, 07:33 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
v6 or 4?
It worked fine until I fixed it!
csaxon is online now   Reply With Quote
Old 11-02-2011, 08:20 PM   #3 (permalink)
4cyl. The error was a P2238
There is one in front that is right there between the engine and radiator but I know Im not that lucky.
Old 11-02-2011, 08:37 PM   #4 (permalink)
View Big Wheezy's Photo Gallery
Any symptoms other than the light? Rough idle and poor fuel economy specifically? 67k is pretty low mileage for the sensor to go out generally... But on a 4 cylinder bank 1 sensor 1 should be the one on the exhaust manifold right on the front, there's a #2 sensor after the cat. Doing some research here by searching the forum for that code it looks like some people have found the problem started from a bad PCV leaking oil into the intake, it may be too late for the sensor but you should check out your intake so you don't ruin another one if it is too far gone.
-Mike
2009 Camry LE - Erisin Nav, K&N drop in, SE grille, LEDs, Gentex homelink mirror, blacked out emblems, CCFL trunk lighting, HIDs, amber fogs
Big Wheezy is offline   Reply With Quote
Old 11-02-2011, 08:55 PM   #5 (permalink)
Here is what happen.
Last week I got an oil change at the dealership, a few days later I have a check engine light come on. It stays on a few days then shuts off. Then comes back on. I take it to the dealer to have it checked and they advised that it was the oxygen sensor.
It says oxygen sensor pumping current circuit low (for a/f sensor) (bank 1 sensor 1)
Then I go to advanced and have them run the same thing and it also says oxygen sensor bank 1 sensor 1.
Dealership said nothing done during an oil change would have cause this.
Old 11-02-2011, 08:57 PM   #6 (permalink)
As far as the car, it runs great, idles fine, doesn't make any strange noises, and gets the same mileage.
Old 11-02-2011, 09:14 PM   #7 (permalink)
View JOET/CAMRY's Photo Gallery
On my Dads 2003 Camry the o2 sensor craped out around 40,000 miles. He went to the gas station and filled the tank and when he restarted the car the check engine light came on. Got the o2 sensor bank 1 sensor 1 replaced and that took care of the problem.
JOET/CAMRY is offline   Reply With Quote
Old 11-02-2011, 09:21 PM   #8 (permalink)
Doing some research here by searching the forum for that code it looks like some people have found the problem started from a bad PCV leaking oil into the intake.
Thanks for mentioning the possible pcv problem. Will check it out on my 2003 Camry. Don't want the o2 sensor going bad on me again. It definitely should have lasted longer. I used to own a 1989 Camry and at 276,000 miles it still had the original o2 sensor. They just don't make them like they used to.
Old 11-02-2011, 09:28 PM   #9 (permalink)
"bad PCV leaking oil into the intake"
Would this be oil where the air intake filter is? Checked the actual air filter area and it is clean.
My car after the oil changing is leaving a little oil on the ground where on my front passenger side of the vehicle. This is new since the oil change, very new and noticeable was going to wait and if it continues or was just for a short bit right after the oil change.
Took the plastic cover off the engine and looked behind it on the passenger side and think found what your were referring to on the PCV. Small hose up high that runs into the air intake part of the vehicle. It looks good and dry but directly below it near the ground almost is an identical hose that half of it is wet along with the aree below it and that is about where oil is leaking on to the ground from my car. Not sure if it is a spill from an oil change or a leak.
Old 11-03-2011, 06:13 AM   #10 (permalink)
I'm not real familiar with a 2004, but the PCV valve should be either stuck in the valve cover or in the hose coming from the valve cover. According to a post I'm reading it should be under the engine cover, passenger side of the motor on the back of the motor pointing towards the firewall, it should screw in. From where that hose ties into the air intake and down into the engine from there is where you'd see oil if it was an issue inside the intake hoses.
From your description that's where you were looking, did you try wiping the area directly below the PCV valve/hose? If there's oil there it's probably a bad PCV. Frankly it'd be pretty unlikely to get a spill in that vicinity doing an oil change, the filter should be on the front and the fill is on the top front, it's possible they over filled it, or it's possible it's just a coincidence that the PCV crapped out at the same time if that is indeed what happened.
-Mike
Old 11-03-2011, 11:09 AM   #11 (permalink)
any help on the location of this sensor would be appreciated.
Old 11-03-2011, 01:04 PM   #12 (permalink)
Gameroom cash: $203000
View Donald E. George's Photo Gallery
One sensor just before the cat and one somewhere downstream of cat. Regards.
Donald E. George is offline   Reply With Quote
Old 11-03-2011, 01:35 PM   #13 (permalink)
Bank 1 is ALWAYS the bank that includes cylinder #1, and sensor #1 is the first one before any catalytic converters, cylinder 1 should be the leftmost cylinder looking from the front (or furthest to the passenger side if you prefer) on a 4 cylinder Camry.
-Mike
Old 11-03-2011, 02:01 PM   #14 (permalink)
Awesome. I will try posting a pic here in a few. It may be the one right on front that is very easy to locate and get to.
The thing is the light doesn't stay on. It came on for a few days and then went off and hadnt been on since.
Old 11-03-2011, 02:03 PM   #15 (permalink)
Did they clear the code when they scanned the car? It will take a few days before the feedback system tests will complete before the code would set again. It's also possible it was an intermittent problem, but I'd definitely keep an eye on things to prevent damage, particularly to the catalytic converter, if there's still a problem.
-Mike
