Speeding Problem/Radar Detector Install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-04-2011, 07:07 PM   #1 (permalink)
Camry Addict
View CamryBeliever's Photo Gallery
I love my Camry.
However I drive 100-200 miles a day and often find myself pushing 90mph!
I have a good Bel RX65 but I can't stand the thought of having the huge cable across my whole dash.
I'd like to mount my radar detector using this http://www.blendmount.com/
You all may have seen this banner on TN
Here's my questions;
1. Do any of you have this mount, what's your feedback?
2. I will only buy if if I can tap in easily to the rear view mirror hopefully. I really don't want to have to run a new wire from my fusebox through the A pillar. Has anyone tapped their rear view mirror power?
Thanks,
Camrybeliever
Black 2009 V6 XLE | JBL audio | TRD springs | TRD 10 spoke 18" | 25% side & 5% rear tints | SE grille | shaved w/blacked out emblems | back up sensors
CamryBeliever is offline   Reply With Quote
Old 11-05-2011, 03:32 AM   #2 (permalink)
View jchin92's Photo Gallery
i dont own a radar and stuff but you can run the wire along the edge then down to a 12v source preferably one that is not constant tho.
Camry LE 2008
jchin92 is offline   Reply With Quote
Old 11-05-2011, 06:56 AM   #3 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
It's a great mount, I use one for my Escort 9500ix. A little tricky to get positioned just how you want it, but once it's there I haven't touched it and hasn't moved.
I had tapped into the rear view mirror power with my older radar detector and older style blend mount... so it's definitely possible. You can also try tapping into the maplights for power as well.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 11-05-2011, 09:36 AM   #4 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
First suggestion-use your cruise control!!! Even the best radar detectors can't save you 100% from the police and I'd hate to hear about you crashing.
Second suggestion-you can tap into the rearview mirror but IMO it looks cleaner running through the A pillar.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
The Following 2 Users Say Thank You to arabianobsession For This Useful Post:
Donald E. George (11-05-2011), Glenn8963 (11-05-2011)
Old 11-05-2011, 11:54 AM   #5 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $477310
iTrader Score: 12 reviews
View bandit's Photo Gallery
My rearview mirror doesn't have a power source so I run mine through the top headliner, down the passengers A pillar, across my glove box and into the cubby hole under my radio and connected to the cigarette adapter.
Old setup where I had coiled cable being visible
My mount is the older version. I reviewed it for BlendMount and its posted on their site somewhere.
You can tap into the rearview mirror for power. Luckily, Valentine sells super long phone cords. Running wires to rearview mirror can be clean install as well.
I don't like to hardwire stuff and mess with the wires unless I really have to.
CarDomain
Old 11-05-2011, 01:43 PM   #6 (permalink)
^ i'd never go back to suction cups after using a blendmount. it's worth the extra money not having your radar detector fall off your windshield when it's cold, or suction cup marks on your windshield.
2005 Camry "LE"
Old 11-05-2011, 08:16 PM   #7 (permalink)
molson.david's Avatar
Gameroom cash: $295253
View molson.david's Photo Gallery
Have the suction cup mounts above the rearview mirror. Bought the non-coiled cord (escort 8500- should be the same cord as the RX65) and ran it from the detector across the headliner and down the A-pillar, through back of glove box and through small hole on the side of the center cubby.
suction caps will hold front of the radar and they more than capable of holding radar weight.
but under vibration force caps gonna get loose.
you can use stiff steel were or thin aluminum profile to make a support for the radar.
use zip tie with screw hole and small screw with nut and washer to attach top end of the support to the mirror leg.
use 3M tape to attach bottom portion of the support to the radar.
I used handle off 1 gal paint can to make support.
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
molson.david is offline   Reply With Quote
Old 11-06-2011, 12:49 AM   #8 (permalink)
must.resist.modding
bandit's Avatar
Originally Posted by cardsfanpb View Post
I wouldn't buy the blendmount.
you don't have to run it into the fusebox or the mirror either.
You can't see any cords except what comes out of the headliner into the detector (2 inches). I think the blendmount's a waste of money, mine stays positioned fine and doesn't bob up and down if you put the suctions on perfect.
Hope this helps
[IMG]file:///C:/Users/Preston/Pictures/%2707%20CAMRY/DSC00269.JPG[/IMG]
#1. you have to upload your pictures to a image hosting site like imageshack.us or photobucket.com. You can not link images from your computer
#2. I would never use suction cups again. After awhile, they fall off. I have a holder that holds my toll pass and it keeps falling off. I don't even have the pass in the holder. The heat itself will weaken the suction. I've even added some water to the suction to get it wet.
Same here. I'll spend a few extra rather than risk my unit from falling. Also, mounting on suction cup also makes it noticeable. I never take mine off. The only time I actually take it off is if I'm in an area I'm not too familiar with or taking it to a parking garage with valet.
With the blendmount, it makes it inconspicuous.
CarDomain
