My 04 V6 has a FIP[formed in place gasket] in that location. Installed correctly,that type of a seal is almost foolproof. Are you sure you don't have a crank seal leaking? Google ToyotaPartsEast,plug in the data for your car. When I looked at the illustrations for both the V6 and I4, I didn't see a gasket for the oil pan. Toyota apparently wants FIP used in that application.I have never removed a pan using FIP but I know the shop manual for my V6 shows the FIP being cut with a special tool. Regards
