I know it should be easy, but was wondering if someone could give me an explanation on how to wire these using stock wiring? Just wanna make sure 100% before i do it.
Thanks in advance fellas
__________________ 2007 I4 CAMRY LE, My ride ==> CLICK
Official gen 6 camry hellaflush picture only thread ==> CLICK
I have, but on my gen 5. Should be pretty similiar though... the stock horns are grounded through the mounting bracket, the hella horns are not. So you will need a short length of wire (with quick disconnect terminal crimped on one end, and ring terminal crimped on the other end) to go from the negative of the horn to the mounting bolt. the stock plug should go right onto the positive of the horn.
Some pictures:
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
The Following User Says Thank You to LE05 For This Useful Post:
Legend! How would i go with connecting the second horn though?
in the same way, that's why I didn't bother taking pictures of the second one. each stock horn has its own plug, but with the hella horns you will need a short length of wire to connect the negative terminals to the mounting bolt for each horn.
2005 Camry "LE"
Are they a dramatic improvement over the stock horn?
only if you want the horns at their loudest. for me, using the stock wiring was more than enough. it's plenty loud and definitely a big improvement over stock with no relays.
2005 Camry "LE"
the relay has 4 terminals. 1 is for the positive wire from the battery. the other is the positive wire to the horns. the 3rd is a ground. and the 4th is the connection from the switch(original harness)
2004 Rav4 I4 FWD
Mileage-21004 as of 8/23/11
