It's possible you have an exhaust leak, if the cat is plugging up as it's failing that can cause undue backpressure which would make things worse, or it could just be the simple fact that even very small amounts of sulfur are very noticible to the human noise, windows up or not and even with the blower off or in recirc you're still getting some outside air, and some of that smell will get pulled along with you even coming out of the tailpipe correctly.
-Mike
2009 Camry LE - Erisin Nav, K&N drop in, SE grille, LEDs, Gentex homelink mirror, blacked out emblems, CCFL trunk lighting, HIDs, amber fogs
