Hesitation, bucking - 2006 V6 Camry XLE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2011, 05:28 PM   #1 (permalink)
Rob4226's Avatar
View Rob4226's Photo Gallery
Hi,
My 2006 V6 Camry XLE feels like there is a delay between hitting the pedal and the car accelerating. I also notice it bucks (changes gears at the wrong time) occasionally when pressing the pedal than backing off of it a little. The hesitation has always been there but lately its been really bothering me because I drove someone else's car (Hyundai Sonata 4 cylinder )and felt how smooth it accelerated and how responsive it was at lower speeds. I know this car has drive by wire which probably has something to do with the problem. I also read some similar stories around the internet. Does anyone know how to alleviate this issue?
Note: I don't think theres anything mechanically wrong. I baby this car and do all the maintenance myself.
Rob4226 is offline   Reply With Quote
Old 11-12-2011, 10:18 PM   #2 (permalink)
View retiredgentleman's Photo Gallery
There should not be any hesitation. My 2005 Camry SE V6 has no hesitation when accelerating.
I'm surprised you say the hesitation has always been there. You should have had that looked at by the dealer when it was new.
If it was OK when new and gradually got worse, I would have suggested getting the fuel injectors flushed.
If you find it annoying, then perhaps a visit to your dealer to allow them to troubleshoot the problem is in order.
retiredgentleman is offline   Reply With Quote
Old 11-12-2011, 11:11 PM   #3 (permalink)
Rob4226's Avatar
I bought this car as a certified preowned toyota from the dealer after it was returned from a lease at 24,000 mi. so I don't really know if it was always there.
It's funny you mentioned the injectors because I just threw in a bottle of lucas injector cleaner with a full tank of "plus" grade gas. (I also switched over to Mobile 1 synthetic oil for first time today and replaced the PCV valve for preventative maintenance).
I've never dealt with fuel injectors before. Is it a job that I can do myself? Cleaning them sounds like a good idea even if its not whats causing the problem.
And to explain a little more what's happening: When I go to accelerate from a standstill to say like 55mph it feels as if I'm not gaining speed fast enough so I give it a little more gas which causes it to down shift (jerks the car sometimes). The amount of hesitation and jerking varies and it's not to the point where the car is unsafe. It just feels like at low speeds the car is not responsive enough to gas peddle.
Old 11-12-2011, 11:23 PM   #4 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1078158
iTrader Score: 7 reviews
Check the EGR Valve...mine did this, and it was the EGR Valve, i replaced it and it went away.
2002 Camry SE V6 "Snow White"
Old 11-13-2011, 12:12 AM   #5 (permalink)
Rob4226's Avatar
Is there a method to check/clean the EGR valve?
I think it's too expensive to replace without knowing for sure it's causing this problem.
Old 11-13-2011, 08:02 AM   #6 (permalink)
Gameroom cash: $246200
View fatngs's Photo Gallery
what condition is ur trans fluid in?
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
fatngs is offline   Reply With Quote
Old 11-13-2011, 10:47 AM   #7 (permalink)
You should eliminate some obvious problem areas such as the air filter. You do your own maintenance, so I assume you change the air filter as required.
It would be a good idea to have an injector flush done by a Toyota service department. They connect the flushing fluid directly to the fuel injector rail to thoroughly clean the injectors.
While at the dealer you could also have them check the cars computer for any error codes that may be set, indicating a failed input sensor.
Old 11-13-2011, 10:47 AM   #8 (permalink)
Rob4226's Avatar
Should be like new. Just replaced the pan gasket and filter and filled it back up with Toyota ATF three months ago (1000 mi.).
Old 11-13-2011, 11:01 AM   #9 (permalink)
Rob4226's Avatar
I'm going to have to bring my car in for the new Nov. 8th recall anyway so maybe I will have them flush the injectors then. Whats the estimated cost of this procedure from Toyota? Thanks.
Old 11-13-2011, 12:49 PM   #10 (permalink)
Tap it with a hammer, and then go for a drive, it usually has carbon build up.
But it is pretty cheap to replace, just order the part online and put it on yourself, i think it's only a few bolts.
