2002 Camry 2.4L Ignition Coil Failure
I have a 2002 Camry 2.4L, ECM 89666-06220, ignition coil 90919-02243. One of the coils has gone out. I got a misfire code on P303. I then moved the cylinder 3 coil to cylinder 4, cleared the code and restarted the car. The new code was P304, bad coil. I found a set of low mileage used coils, 90080-19023. The dealer says this number was one of the three options for 2002. But the pin-to-pin ohm values don’t match. The 90080-19023 pin ohms, 1-2= 348, 1-3=667, 1-4= 490, 2-3= 1100, 2-4= 912, 3-4= open. The 90919-02243 pin ohms, 1-2= 390, 1-3= 673, 1-4=940, 2-3= 1154, 2-4=1403, 3-4= open. I’m wondering if anybody else has successfully done this substitution and not burned up their ECM ? The wrecking yards say they will work, call me a skeptic!
