the bulbs could be burnt out..... im not sure if on the older gen 5 if it uses LED or a mini bulb to light up the warning indicators.... you can remove the cluster and see if there are little black sockets along the bottom.... if there are, remove (twist) and replace bulb; if there are no sockets then it uses LED and the whole thing will have to be taken apart and new LED chips soldered into place
far as the start up warning lights:
maint reqd, oil, check engine, abs, brake, airbag, battery, seat belt, and if u have it vsc, trac off, and skid
Black 2006 Camry SE 2azfe automagic - daily driver
White 1987 VW Fox 2-door wagon 2.0 3A 8V 5 speed - because reliability is boring
